电子发烧友论坛扫一扫,分享给好友
你好
我对Vivado 2017.2以及2017.1.Vivado在打开项目或向项目添加新源时关闭了。 重新安装并没有解决问题。 任何帮助,将不胜感激。 以上来自于谷歌翻译 以下为原文 Hi I have an issue with Vivado 2017.2 and also 2017.1. Vivado closes when opening a project or adding new source to project. Reinstallation did not solve the problem. Any help would be appreciated. |
8个回答
嗨@ dark_scientist,
您使用的是哪种特定操作系统? 您是否在使用工具示例设计观察相同的行为? 谢谢& 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 以上来自于谷歌翻译 以下为原文 Hi @dark_scientist, Which specific OS are you using? Are you observing the same behavior with the tool example designs? Thanks & Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
@dark_scientist,
在Vivado关闭之前,您是否看到任何错误消息? 根据您的描述,它看起来像崩溃。 请分享下面AR中提到的崩溃日志文件。 https://www.xilinx.com/support/answers/55854.html 另请参阅以下论坛帖子是否有帮助: https://forums.xilinx.com/t5/Implementation/Vivado-2017-1-Crashed-When-Opening-Implemented-Design/td-p/762388 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @dark_scientist, Do you see any error message before Vivado closes? From your description, it looks like crash. Please share the crash log file as mentioned in below AR. https://www.xilinx.com/support/answers/55854.html Also see if the below forum thread helps: https://forums.xilinx.com/t5/Implementation/Vivado-2017-1-Crashed-When-Opening-Implemented-Design/td-p/762388 --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
Windows 10 Pro X64版本:10.0.14393 Build 14393Yes。
我正在观察工具示例设计的相同行为。 以上来自于谷歌翻译 以下为原文 Windows 10 Pro X64 Version: 10.0.14393 Build 14393 Yes. I'm observing the same behavior with the tool example designs. |
没有任何消息,只是关闭。
但我删除了该线程中提到的名为protobuf-java-x.x.jar的.jar文件。 现在,vivado永远不会打开并给我跟踪错误.http://i.imgur.com/ZftIj1N.png 以上来自于谷歌翻译 以下为原文 There aren't any messages, just closing. But i deleted .jar file named protobuf-java-x.x.jar as mentioned in that thread. Now, vivado never opens and giving me following error. http://i.imgur.com/ZftIj1N.png |
你好@ dark_scientist
检查以下AR以获取您收到的错误消息: https://www.xilinx.com/support/answers/57386.html 希望这可以帮助。 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @dark_scientist Check the below AR for the error message you are getting: https://www.xilinx.com/support/answers/57386.html Hope this helps. Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
错误日志:
##发生了意外错误(EXCEPTION_ACCESS_VIOLATION)#Stack:没有可用的堆栈跟踪,请改用hs_err_.dmp。 以上来自于谷歌翻译 以下为原文 Error Log: # # An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION) # Stack: no stack trace available, please use hs_err_ |
嗨@ dark_scientist,
>>是的。 我正在观察工具示例设计的相同行为。 这证实了问题在于安装而不是任何特定设计。 您能否附上环境报告> report_environment -file sytem_info.txt来查看系统变量? 您是否使用管理员权限运行该工具? 您现在是否正在获取上述启动器超时错误或工具启动然后关闭? 请在此处附上日志(作为附件),如AR55854中所示。 谢谢& 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 以上来自于谷歌翻译 以下为原文 Hi @dark_scientist, >>Yes. I'm observing the same behavior with the tool example designs. This confirms that the issue is with installation and not any specific design. Can you please attach the environment report > report_environment -file sytem_info.txt to have a look at the system variables? Are you running the tool with admin privileges? Are you now getting the launcher timeout error as mentioned above or the tool starts and then closes? Please attach the logs here (as attachments) as given in AR55854. Thanks & Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
我似乎与Windows Server 2012和2017.2有相同的错误。我无法打开任何项目,它与EXCEPTION_ACCESS_VIOLATION崩溃。
希望这很快就能解决,我现在正在尝试2017.1。 以上来自于谷歌翻译 以下为原文 I seem to have the same error with Windows Server 2012 and 2017.2. I can not open any project, it crashes with EXCEPTION_ACCESS_VIOLATION. Hope this will be solved soon, I'm now trying 2017.1. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:48 , Processed in 0.953397 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3719
