电子发烧友论坛扫一扫,分享给好友
嗨,
当我在Linux系统上安装Vivado 2017.2时,由于与Vivado安装无关的原因,系统在安装过程中崩溃了。 这给我留下了一个带有“半安装”vivado的系统,一些文件到位,但很多都丢失了。 UG973中描述的卸载过程不起作用,因为没有 /.xinstall/Vivado_2017.2/xsetup 这可以用'-Uninstall'开头。 所以我用'rm -rf'删除了 /.xinstall/Vivado_2017.2 /Vivado/2017.2 并试图再次安装。 但是安装程序不允许我使用之前的版本,并假装仍然安装了2017.2。 必须有其他地方崩溃的安装留下一些痕迹。 问题:在如此崩溃的安装后如何(手动)清理? 最诚挚的问候,沃尔特 以上来自于谷歌翻译 以下为原文 Hi, when I installed Vivado 2017.2 on a Linux system the system crashed in the middle of the installation process, due to reasons which had nothing to do with the Vivado installation. That left me with a system with a 'half-installed' vivado, some files in place, but many missing. The uninstall procedure described in UG973 didn't work, because there was no which could be started with '–Uninstall'. So I removed with 'rm -rf' and tried to install again. However the installer does not allow me to use the previous Question: How to (manually) cleanup after such a crashed installation ? With best regards, Walter |
3个回答
你好@ wfjmueller,
我们曾经回过头来看过这个问题,但从来没有能够重现它。 我认为原因是因为/ apps / xilinx下的.xinstall目录。 在那之下会有一个Vivado_2017.2目录。 尝试删除此Vivado_2017.2,然后重新运行安装程序,看看它是否允许您现在再次安装,而不会向您显示仍然在该位置安装2017.2。 希望这可以帮助。 问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @wfjmueller, We came across this issue once time back but never able to reproduce it. I think the reason is because of the .xinstall directory under /apps/xilinx. There would be a Vivado_2017.2 directory under that. Try deleting this Vivado_2017.2 one and re-running the installer and see if it will allow you now to install again without indicating to you that there still a 2017.2 installation in the Hope this helps. Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好@anatoli,
我在我的主目录中有一个'.xilinx'目录,但这基本上是空的,只有find .xinstall .xinstall / .cache .xinstall / .cache / .data 只有三个目录,里面没有常规文件。 在'/ apps / xilinx'下你是什么意思? 最诚挚的问候,沃尔特 以上来自于谷歌翻译 以下为原文 Hallo @anatoli, I've a '.xilinx' directory in my home directory, but that is essentially empty, a find gives only .xinstall .xinstall/.cache .xinstall/.cache/.data just three directories with no regular files inside. What do you mean with under '/apps/xilinx' ? With best regards, Walter |
@wfjmueller
您必须已删除可执行文件。 Xilinx / SDK文件夹中也必须有一些条目,Xilinx / Vivado_HLS文件夹(如果已创建)。 您也可以尝试删除创建的快捷方式。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @wfjmueller You must have deleted the executables. There must be some entries in Xilinx/SDK folder, Xilinx/Vivado_HLS folder too(if created). You can also try deleting the shortcuts created. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1201浏览 1评论
/9
GMT+8, 2025-12-14 18:37 , Processed in 0.537188 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3492
