电子发烧友论坛|
当我完成SDx 2017.2的安装时,没有安装System Generator的选项。
我正在运行从Xilinx下载的安装程序:https://www.xilinx.com/member/forms/download/xef.html?filename = Xilinx_SDx_2017.2_sdx_0823_1.tar.gz 安装程序的文档将安装Vivado Design Suite System Edition,但没有安装System Generator的选项(见下图)。 如何安装System Generator? 我需要使用其他安装程序吗? 以上来自于谷歌翻译 以下为原文 When I run through the installation for SDx 2017.2, there are no options to install System Generator. I'm running the installer downloaded from Xilinx here: https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_SDx_2017.2_sdx_0823_1.tar.gz The documentation for the installer states that it will be installing Vivado Design Suite System Edition, but there are no options to install System Generator (see image below). How can I install System Generator? Do I need to use a different installer? |
10个回答
你好@ wpunchak
我已与开发团队确认,当2017.2 SDx发布时,它仍然是单独的,我们从2017年开始整合SDx + Vivado.3内部和2017.4生产。 什么包含在2017.2中SDx由营销定义,从我们看到,它包括SDx所依赖的工具,如Vivado,SDK和HLS,在GUI中显示为“Vivado”预选,不允许用户取消选择它 ,因为所有这些都需要运行SDx。 Sysgen不是它的一部分,因为SDx在没有Sysgen的情况下运行良好。 即使对于Vivado系统版,Sysgen也是一个单独的选项,默认选择,但用户可以取消选择它,因此它不是System Edition必须的。 如果您想使用SysGen v2017.2,则需要下载并安装2017.2 Vivado而不是2017.2 SDx。 或者您可以使用较新版本的SDx - 2017.4或以上版本是组合的SDx + Vivado图像,Sysgen作为单独的选项包含在内,默认情况下未经营销决策选择。 例如。: 希望以上是清楚的。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @wpunchak I have confirmed with the developement team that when 2017.2 SDx was released, it still was by itself, we have the combined SDx + Vivado starting from 2017.3 Internal and 2017.4 Production. What’s included in 2017.2 SDx was defined by marketing, from what we see, it included the tools that SDx depends on, like Vivado, SDK and HLS , showing in GUI as “Vivado” pre-selected and does not allow user to de-select it, as all these are required to run SDx. Sysgen is not part of it, as SDx works well without Sysgen. Even for the Vivado System Edition, Sysgen is a separate option, just by default selected but user can de-select it, so it’s not a must for System Edition. If you want to use SysGen v2017.2, you'd need to download and install the 2017.2 Vivado instead of the 2017.2 SDx. Or you can move to use the newer version of SDx -- 2017.4 or the above versions are the combined SDx + Vivado image, Sysgen is included as a separate option, by default not selected though with the marketing decision. e.g.: Hope the above is clear. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
你好@ wpunchak,
从下面的链接中可以看到,System Generator for DSP是Vivado®HL系统版的一部分,而不是SDx的一部分。 https://www.xilinx.com/products/design-tools/vivado/integration/sysgen.html#buy 从Vivado安装GUI,您还可以看到此注释: 请注意,SysGen与Vivado System Edition安装一起安装。 选择要安装的Vivado系统版本后,在下一个安装窗口中没有选项(类似于SDK)来选择/取消选择SysGen。 但是,一旦安装了Vivado System Edition,就可以在开始菜单下找到System Generator,例如: 希望这可以帮助。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @wpunchak, From the below link you can read that System Generator for DSP is part of the Vivado® HL System Edition and not of the SDx. https://www.xilinx.com/products/design-tools/vivado/integration/sysgen.html#buy From the Vivado install GUI you can also see this note: Please note that SysGen gets installed together with the Vivado System Edition installation. There won't be an option (similar to SDK) to select/unselect SysGen on the next installation window after you've selected the Vivado System edition to be installed. However, once the Vivado System Edition is installed, under the start menu you'd then be able to find System Generator, e.g.: Hope this helps. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
谢谢@ anatoli,但我仍然对Xilinx产品的不同之处感到困惑。
从2017.2 SDx的文档中可以看出: SDSoC™的安装包括以下内容: •SDSoC环境,包括基于Eclipse / CDT的GUI,高级系统编译器和 ARM GNU工具链 •Vivado®DesignSuite系统版,带有Vivado高级综合(HLS)和 Xilinx®软件开发套件(SDK)您能否澄清一下安装了SDx的Vivado Design Suite系统版和独立的Vivado HL系统版之间的区别? SDx安装是否仅安装部分Vivado Design Suite系统版? 与2017.2 SDx一起安装的Vivado Design Suite系统版不包括System Generator。 以上来自于谷歌翻译 以下为原文 Thanks @anatoli, but I'm still confused about where Xilinx products differ. From the documentation for the 2017.2 SDx it states: The installation of SDSoC™ includes the following:• SDSoC environment, including an Eclipse/CDT-based GUI, high-level system compiler, andARM GNU toolchain• Vivado® Design Suite System Edition, with Vivado High-Level Synthesis (HLS) and theXilinx® Software Development Kit (SDK)Could you clarify what is different between the Vivado Design Suite System Edition installed with the SDx and the standalone Vivado HL System Edition? Does the SDx installation install only a partial Vivado Design Suite System Edition? The Vivado Design Suite System Edition installed with the 2017.2 SDx does not include the System Generator. |
你好@ wpunchak,
为这种困惑道歉。 当我们谈论Vivado系统版时,如果安装了这个版本,无论是通过“独立”Vivado Design Suite安装还是SDx安装完成,SysGen都是此安装的一部分。 如果您没有SysGen,请将其视为Vivado Design Edition,因为Vivado System Edition是VivadoDesign Edition + SysGen for DSP的超集。 运行SDx xsetup安装程序将获得与2017.2 Vivado xsetup安装程序相同的Vivado Design Suite,并提供与Vivado System Edition安装相同的选项。 SDx xsetup安装程序是Vivado System Edition版本的超集。 BTW,FYI - 安装Vivado System Edition后,您只需要一个VivadoSystem Edition许可证。 安装SDX后,您需要VivadoSystem Edition许可证+ SDSoC许可证。 希望以上是清楚的。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @wpunchak, Apologies for the confusion. When we are talking about Vivado System Edition, if this is installed, no matter if this is done via "stand alone" Vivado Design Suite installation or SDx installation, SysGen comes as part of this installation. If you have no SysGen, consider this to be Vivado Design Edition, as Vivado System Edition is a superset of Vivado Design Edition + SysGen for DSP. Running the SDx xsetup installer would get you the same Vivado Design Suite as the 2017.2 Vivado xsetup installer, and offers the same options as the Vivado System Edition installation. The SDx xsetup installer is a super-set of the Vivado System Edition version. BTW, FYI - when having Vivado System Edition installed, you'd just need a Vivado System Edition license. Having SDx installed, you'd need a Vivado System Edition license + SDSoC license. Hope the above is clear. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
谢谢@anatoli,你的解释澄清了差异。
我唯一的问题是,现在我安装了SDx 2017.2,系统生成器没有快捷方式。 我查看了“sysgen.bat”的安装目录,但它不存在。 2018.2不是这种情况,对于该安装,快捷方式和bat文件位于正确的位置。 以上来自于谷歌翻译 以下为原文 Thanks @anatoli, your explanation clarified the differences. My only issue is, now that I've installed SDx 2017.2, there is no shortcut for system generator. I've looked in the install directory for "sysgen.bat" and it doesn't exist. This wasn't the case with 2018.2, for that installation the shortcut and bat files were in the correct location. |
你好@ wpunchak,
你是对的,我刚试过,确实,SysGen没有安装2017.2 SDx,与SDx 2018.2不同。 我已就此事向开发团队提出了一个问题。 一旦我收到他们的回复,我会更新你的。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @wpunchak, You are right, I have just tried and indeed, SysGen ins't there with 2017.2 SDx installation, unlike with SDx 2018.2. I have raised an issue with the development team regarding this matter. I will update you once I hear back from them. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好@ wpunchak
我已与开发团队确认,当2017.2 SDx发布时,它仍然是单独的,我们从2017年开始整合SDx + Vivado.3内部和2017.4生产。 什么包含在2017.2中SDx由营销定义,从我们看到,它包括SDx所依赖的工具,如Vivado,SDK和HLS,在GUI中显示为“Vivado”预选,不允许用户取消选择它 ,因为所有这些都需要运行SDx。 Sysgen不是它的一部分,因为SDx在没有Sysgen的情况下运行良好。 即使对于Vivado系统版,Sysgen也是一个单独的选项,默认选择,但用户可以取消选择它,因此它不是System Edition必须的。 如果您想使用SysGen v2017.2,则需要下载并安装2017.2 Vivado而不是2017.2 SDx。 或者您可以使用较新版本的SDx - 2017.4或以上版本是组合的SDx + Vivado图像,Sysgen作为单独的选项包含在内,默认情况下未经营销决策选择。 例如。: 希望以上是清楚的。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @wpunchak I have confirmed with the developement team that when 2017.2 SDx was released, it still was by itself, we have the combined SDx + Vivado starting from 2017.3 Internal and 2017.4 Production. What’s included in 2017.2 SDx was defined by marketing, from what we see, it included the tools that SDx depends on, like Vivado, SDK and HLS , showing in GUI as “Vivado” pre-selected and does not allow user to de-select it, as all these are required to run SDx. Sysgen is not part of it, as SDx works well without Sysgen. Even for the Vivado System Edition, Sysgen is a separate option, just by default selected but user can de-select it, so it’s not a must for System Edition. If you want to use SysGen v2017.2, you'd need to download and install the 2017.2 Vivado instead of the 2017.2 SDx. Or you can move to use the newer version of SDx -- 2017.4 or the above versions are the combined SDx + Vivado image, Sysgen is included as a separate option, by default not selected though with the marketing decision. e.g.: Hope the above is clear. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@anatoli,谢谢你的肯定。
我选择2017.2软件的原因是因为我正在评估MathWorks HDL Workflow Advisor。 使用Matlab 2018A,他们已经确认并测试的最新版本是Vivado 2017.2。 接下来,我将评估System Generator工作流程。 从Xilinx的文档来看,最新的System Generator with Vivado 2018.1似乎只支持Matlab 2017b。 它是否正确? 我们将购买一些最新的Zync UltraScale + RFSOC,以充分利用板载ADC,并尝试为我们的团队建立工作流程。 以上来自于谷歌翻译 以下为原文 @anatoli, thanks for confirming that. The reason I had selected the 2017.2 software was because I was evaluating MathWorks HDL Workflow Advisor. With Matlab 2018A, the most recent release they had confirmed and tested with was Vivado 2017.2. Next I'll be evaluating the System Generator workflow. From Xilinx's documentation, it looks as though the latest System Generator with Vivado 2018.1 will only support up to Matlab 2017b. Is this correct? We're going to be purchasing some of the latest Zync UltraScale+ RFSOCs to take advantage of the onboard ADCs and are trying to establish a workflow for our team. |
你好@ wpunchak,
实际上,SysGen 2018.1仅支持MathWorks的MATLAB版本:2017a和2017b。 但是,SysGen 2018.2版本支持R2018a(而不是2017.2版,如MathWorks网站所示)。 见UG973第6页(v 2018.2): https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf 网站上一定有错误,而不是2017.2,应该有2018.2版本的Vivado工具。 UG973(v2017.2),第77页表明支持的带有SysGen 2017.2的MATLAB版本仅为:R2016a,R2016b和R2017a: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf 如果您有任何其他问题,请告诉我。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @wpunchak, Indeed, SysGen 2018.1 only supports MATLAB Versions: 2017a and 2017b from MathWorks. However R2018a is supported with SysGen 2018.2 version (and not with 2017.2, as indicated on the MathWorks website). See page 6 of UG973 (v 2018.2): https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf There must be a mistake on the site and instead of 2017.2, there should be 2018.2 version of Vivado tools. UG973 (v2017.2), page 77 indicates that the Supported MATLAB Versions with SysGen 2017.2 are: R2016a, R2016b, and R2017a only: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf If you have any further questions for me, please let me know. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好@阿纳托利,
在Matlab R2018A中创建了一个simulink项目之后,我添加了一个Xilinx系统生成器模块。 如果我然后双击此系统生成器块我收到以下错误: 你知道如何解决上述错误吗? 我不相信SysGen 2018.2与Matlab R2018A兼容。 谢谢, 韦恩 以上来自于谷歌翻译 以下为原文 Hello @anatoli, After creating a simulink project in Matlab R2018A, I added a Xilinx System Generator Block. If I then double click this System Generator Block I get the following error: Do you know how to resolve the above error? I'm not confident that SysGen 2018.2 is compatible with Matlab R2018A. Thanks, Wayne |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 15:52 , Processed in 1.093924 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
819
