扫一扫,分享给好友
我一直在使用2017.2在定制板上合成和实现我们的设计而没有任何问题。
最近,我们的软件升级到2017.4版本,突然间我看到以下错误:[Common 17-345]找不到功能'Synthesis'和/或设备'xczu9eg'的有效许可证。 我查看了许可证文件,但没有任何地方表明存在任何部分限制。 实际上,根本没有提到任何部件。 不确定这意味着什么。 我们的浮动许可证适用于2018.10。 我在同一部分成功使用2017.2。 还有一个关于许可证服务器需要在2017.3及更高版本上使用Flex 10.14.1的说明 - 我已经验证我们正在使用10.14.1。 任何帮助将不胜感激。谢谢。 以上来自于谷歌翻译 以下为原文 I've been using 2017.2 for synthesis and implementation of our design on a custom board without issues. Recently, our software was upgraded to the 2017.4 version and all of a sudden I see the error below: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xczu9eg'. I've looked at the license file but nowhere in there indicates any part limitation. Actually, there is no mention of any parts at all. Not sure what this means. Our floating license is good for 2018.10. I've been successfully using 2017.2 on the same part. There is also a note about the license server needing to use the Flex 10.14.1 on versions 2017.3 and up - I've verified that we are using the 10.14.1. Any help would be greatly appreciated. Thanks. |
7个回答
嗨@caballes,
Vivado 2017.3及更高版本的工具需要新的LMGRD实用程序版本11.14才能正确提取浮动许可证。 请注意,主机上需要新的MSVCC可分发版本,特别是适用于Windows操作系统的MSVCC 2015。 我已附上以下文档以协助安装和设置过程。 我还包括了我们的版本限制兼容性图表,以及显示Vivado软件所需的许可证版本。 在您的情况下,您需要2017.12及更高版本的限制才能使用2017.4工具。 https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2017-3-Licensing-Changes/td-p/799675https://www.xilinx.com/support/answers/69969.html https://www.xilinx.com/support/answers/33770.html 谢谢你,德文 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @caballes, The Vivado 2017.3 and later tools require the new LMGRD utilities version 11.14 for the floating licenses to pull correctly. Note that a new MSVCC distributable version is required on the host machine, specifically MSVCC 2015 for Windows operating systems. I have attached the documentation below to assist in the install and setup process. I have also included our version limit compatibility chart as well showing what version of the license is required for the Vivado software. In your case you would need a version limit of 2017.12 and higher to work with the 2017.4 tools. https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2017-3-Licensing-Changes/td-p/799675 https://www.xilinx.com/support/answers/69969.html https://www.xilinx.com/support/answers/33770.html Thank you, Devin View solution in original post |
嗨@caballes,
Vivado 2017.3及更高版本的工具需要新的LMGRD实用程序版本11.14才能正确提取浮动许可证。 请注意,主机上需要新的MSVCC可分发版本,特别是适用于Windows操作系统的MSVCC 2015。 我已附上以下文档以协助安装和设置过程。 我还包括了我们的版本限制兼容性图表,以及显示Vivado软件所需的许可证版本。 在您的情况下,您需要2017.12及更高版本的限制才能使用2017.4工具。 https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2017-3-Licensing-Changes/td-p/799675https://www.xilinx.com/support/answers/69969.html https://www.xilinx.com/support/answers/33770.html 谢谢你,德文 以上来自于谷歌翻译 以下为原文 Hi @caballes, The Vivado 2017.3 and later tools require the new LMGRD utilities version 11.14 for the floating licenses to pull correctly. Note that a new MSVCC distributable version is required on the host machine, specifically MSVCC 2015 for Windows operating systems. I have attached the documentation below to assist in the install and setup process. I have also included our version limit compatibility chart as well showing what version of the license is required for the Vivado software. In your case you would need a version limit of 2017.12 and higher to work with the 2017.4 tools. https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2017-3-Licensing-Changes/td-p/799675 https://www.xilinx.com/support/answers/69969.html https://www.xilinx.com/support/answers/33770.html Thank you, Devin |
德文,
谢谢回复。 我还是卡住了。 我们的Linux许可证服务器正在运行Flexlm实用程序v11.14,1。 刚刚在今天早些时候证实了 由于我们使用Linux,我们不需要MSVCC更新,对吧?许可证管理器显示我们的基于证书的浮动许可证的版本限制为2018.10。 我试过两次重启机器但没有成功。 还有其他提示吗? 再次感谢。 以上来自于谷歌翻译 以下为原文 Devin, Thanks for the reply. I'm still stuck. Our Linux license server is running the Flexlm utilities v11.14,1. Just confirmed that earlier today. Since we are using Linux, we don't need the MSVCC update, right? The license manager shows that our Certificate based floating license has a version limit of 2018.10. I tried rebooting the machine twice already with no success. Any other hints? Thanks again. |
嗨@ CABALLES,
1.您在Vivado 2017.4上使用哪个Linux版本? 2.运行“report_environment -file env.txt”tcl命令并提供要评估的env.txt文件。 3.提供您在合成阶段所面临的确切错误的快照。 4.提供您要定位的确切零件名称。 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @caballes, 1. Which linux version you are using for Vivado 2017.4? 2. Run "report_environment -file 3. Provide the snapshot of the exact error which you are facing in synthesis phase. 4. Provide the exact part name which you want to target. Regards, hemangd |
你好@ CABALLES,
你可以打开航行到这个位置,例如:../ xilinx / Vivado_2017.3 / Vivado/2017.3 / bin / unwrapped / lnx64.o然后从这里运行这个命令:lmutil lmstat-a -c @(eglmutil lmstat -a-c 2100 @ ANATOLI_PC) 然后请查看lmgrd是否已启动且xilinxd是否也已启用,然后查看服务器启动的flexlm实用程序的版本? 你看到lmgrd和xilinxd的v11.14吗? 你能确认吗? 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @caballes, Can you please open navigate to the location such as e.g.: ../xilinx/Vivado_2017.3/Vivado/2017.3/bin/unwrapped/lnx64.o and then from here, please run this command: lmutil lmstat –a –c Then please see if lmgrd is UP and xilinxd is UP too and then, see what version of flexlm utilities the server is/was started with? Do you see v11.14 for both lmgrd and xilinxd? Can you confirm on this please? Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好@ CABALLES,
这个主题仍然是开放的,等着你。 如果您的问题已得到解答和/或您的问题已得到解决,请将已解决的问题标记为已接受的解决方案(有关详细信息,请访问此处:https://forums.xilinx.com/t5/help/faqpage/faq-category -id /解决方案#)。 这样,主题即可完成。 如果没有解决/回答,请回复主题。 提前谢谢,祝你有个美好的一天。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @caballes, This topic is still open and is waiting for you. If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then. If this is not solved/answered, please reply in the thread. Thanks in advance and have a great day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
谢谢您的帮助。
经过仔细审查后发现,我们的许可证服务器没有运行最新的Flexlm实用程序v11.14,1。 现在一切都在运转。 以上来自于谷歌翻译 以下为原文 Thanks for the help. After careful review, it turned out that our license server wasn't running the latest Flexlm utilities v11.14,1. Everything's working now. |
只有小组成员才能发言,加入小组>>
2171 浏览 7 评论
2611 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2082 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2198 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
433浏览 1评论
1531浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2181浏览 0评论
511浏览 0评论
1649浏览 0评论
GMT+8, 2024-5-3 03:30 , Processed in 1.101565 second(s), Total 78, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
