扫一扫,分享给好友
大家好,
今天我将Vivado升级到2017年的Update 1,以便访问XC7S25,XC7A12和XC7A25设备。 据我所知,更新成功完成; 2017.4是我唯一的Vivado版本,安装程序在重新运行时没有找到任何候选安装。 这告诉我安装程序认为我的安装已更新。 但是,当我尝试在Vivado GUI中创建项目时,我无法为新项目选择任何这些部分(现在让我们关注XC7S25)。 此外,当我以类似于以下命令的批处理模式运行Vivado时,Vivado会抱怨“无法找到所选部分”: create_project -force -name bscan_spi_xc7s25 -part xc7s25-csga324-1通过我的Xilinx安装目录,看起来安装程序成功了; 自从我安装2017.4以来,我发现了大量更新的文件。 甚至今天也更新了installed_devices文本文件。 但是没有安装xc7s25的迹象! william @ xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ ls -l data / parts / installed_devices.txt -rw-rw-rw- 1 root root 48572 Feb 22 14:56 data / parts / installed_devices.txt william @ xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ grep“xc7s50”data / parts / installed_devices.txt 'xc7s50', 'xc7s50'=> { william @ xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ grep“xc7s25”data / parts / installed_devices.txt william @ xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4 $我在更新时错过了一些步骤,还是这种预期的行为而我错过了更新的重点? 以上来自于谷歌翻译 以下为原文 Hello all, Today I upgraded Vivado to Update 1 of 2017.4 in order to get access to to the XC7S25, XC7A12, and XC7A25 devices. The update completed successfully as far as I can tell; 2017.4 is the only Vivado version I have, and the installer doesn't find any candidate installations to patch when I rerun it. This tells me the installer thinks my installation has been updated. However, when I try to create a project in the Vivado GUI, I can't select any of these parts for a new project (let's focus on XC7S25 for now). Additionally, when I run Vivado in batch mode similar to the following command, Vivado complains "the selected part cannot be found": create_project -force -name bscan_spi_xc7s25 -part xc7s25-csga324-1Going through my Xilinx installation directory, it does look like the installer succeeded; I find plenty of updated files since I installed 2017.4. Even the installed_devices text file was updated today. But there's no sign of xc7s25 being installed! william@xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ ls -l data/parts/installed_devices.txt -rw-rw-rw- 1 root root 48572 Feb 22 14:56 data/parts/installed_devices.txtwilliam@xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ grep "xc7s50" data/parts/installed_devices.txt 'xc7s50', 'xc7s50' => {william@xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ grep "xc7s25" data/parts/installed_devices.txt william@xubuntu-dtrain:/opt/Xilinx/Vivado/2017.4$ Did I miss some step when updating, or is this expected behavior and I missed the point of the update? |
3个回答
这是来自WebPack安装吗?
如果是这样,以下内容可能适用: https://www.xilinx.com/support/answers/70505.html -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Is this coming from a WebPack installation? If so, the following may apply: https://www.xilinx.com/support/answers/70505.html ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
这是来自WebPack安装吗?
如果是这样,以下内容可能适用: https://www.xilinx.com/support/answers/70505.html -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Is this coming from a WebPack installation? If so, the following may apply: https://www.xilinx.com/support/answers/70505.html ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好kmorris,
我为延迟回复而道歉。 是的,我的问题来自Webpack安装。 我忘了做升级安装到设计版的部分。 自从我安装了2017.4.1 Webpackfirst,即。 从说明错误的顺序我认为升级将锁定我的Vivado时期,直到我购买完整的许可证。 但升级到“Design Edition”后,我现在可以访问新设备了。 Vivado仍然认为我只使用Webpack版本(我猜每个设备都必须检查当前的许可证 - 我告诉安装程序跳过尝试验证Design Edition的许可证)。 谢谢指针,我认为这个问题解决了! 以上来自于谷歌翻译 以下为原文 Hello kmorris, I apologize for the delay in replying. Yes, my issues are coming from a Webpack installation. I forgot to do the part where it says to upgrade my installation to Design Edition. Since I installed 2017.4.1 Webpack first, i.e. in the wrong order from the instructions I was under the impression that the upgrade would lock me out of Vivado period until I purchased a full license. But upon upgrading to "Design Edition", I can now access the new devices. Vivado still thinks I'm only using the Webpack edition (I guess each device must check for the current license- I told the installer to skip attempting to validate a license for the Design Edition). Thank you for the pointer, I consider this issue solved! |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2219 浏览 9 评论
3296 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
657浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
465浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
228浏览 1评论
671浏览 0评论
1865浏览 0评论
GMT+8, 2024-10-2 06:01 , Processed in 1.169479 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
