扫一扫,分享给好友
你好,
在尝试实现设计时,我得到了“放置30-4错误”: [放置30-4]设计利用率非常高。 运行report_utilization命令以查看设计利用率。 放弃放置机会非常低,可以放置。 要使用“place.skipUtilizationCheck”参数集跳过此检查运行展示位置。 我附上了综合后利用率报告,因为我看不到哪些资源利用率很高。 任何帮助表示赞赏。 装置:XC7A100T 工具:Xilinx Vivado 2016.1 最好的祝福, AK Utilization.txt 10 KB 以上来自于谷歌翻译 以下为原文 Hello, I am getting a "Place 30-4 Error" when trying to implement the design: [Place 30-4] Design utilization is very high. Run report_utilization command to see design utilization. Abandoning placement as chances are very low that placement is possible. To skip this check run placement with 'place.skipUtilizationCheck' parameter set. I have attached the post-synthesis utilization report, as I can not see which of the resources that have high utilization. Any help is appreciated. Device: XC7A100T Tool: Xilinx Vivado 2016.1 Best regards, AK |
14个回答
你好,
这里还附有控制集信息。 最好的祝福, AK ControlSets.txt 2 KB 以上来自于谷歌翻译 以下为原文 Hello, Here is also the Control Set Information attached. Best regards, AK |
@ aakx87,
你能尝试使用不同的实施策略吗? 同时检查以下论坛帖子是否有用: https://forums.xilinx.com/t5/Implementation/Place-30-4-Error/m-p/658011 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @aakx87, Can you please try using different implementation strategies? Also check if the below forum thread is helpful: https://forums.xilinx.com/t5/Implementation/Place-30-4-Error/m-p/658011 --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
谢谢您的回复。 如果我runset_param place.skipUtilizationCheck 1,我可以完成实现 但是,我不明白,该工具认为哪种资源具有高利用率 - 我在哪里可以找到该信息? 以上来自于谷歌翻译 以下为原文 @syedz Thank you for your reply. I can finish implementation if I run set_param place.skipUtilizationCheck 1 However, I do not understand, which resource, the tool sees as having a high utilization - Where can I find that information? |
@ aakx87,
从利用率和控制集报告中,我认为设计应该非常适合设备。 有一个类似的开放CR-937716,将于2016年修复。 现在,您可以使用set_param place.skipUtilizationCheck 1开关继续前进 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @aakx87, From the utilization and control set report, i think the design should eaisly fit in the device. There is an similar open CR-937716 which is to be fixed in 2016.3. For now you can move forward by using set_param place.skipUtilizationCheck 1 switch --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
我可以在任何地方打开“CR-937716”,看看它被描述为什么? 谢谢。 以上来自于谷歌翻译 以下为原文 @syedz Can i anywhere open "CR-937716" too see what it is described as? Thank you. |
@ aakx87
不,那是不可能的。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @aakx87 No that wont be possible. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
感谢您的时间。 我已成功运行该命令的实现,但现在我收到以下警告: [放置30-770]高寄存器利用率迫使place_design每个片最多放置8个寄存器,这可能会影响放置成功和/或路由拥塞。 我附上了实施后控制集和利用率报告 - 这是否仍然适用于您提到的开放案例? ControlSets.txt 2 KB Utilization.txt 11 KB 以上来自于谷歌翻译 以下为原文 @syedz Thank you for your time. I have run the implementation with that command succesfully, but now I'm getting the following warnings: [Place 30-770] High register utilization is forcing place_design to place up to 8 registers per slice which may impact placement success and/or routing congestion. I have attached the post-implementation control sets and utilization report - Does this still apply to the open case you mention? |
@ aakx87,
你能否分享post opt dcp文件? --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @aakx87, Can you please share the post opt dcp file? --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedzOfcourse - 我可以上传某个不公开的地方吗?
以上来自于谷歌翻译 以下为原文 @syedz Ofcourse - Can I upload somewhere not public? |
@ aakx87,
发给你一条私信。 请检查并回复。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @aakx87, sent you a private message. Please check and respond. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
谢谢,我已经回复了你的PM。 以上来自于谷歌翻译 以下为原文 @syedz Thank you, I have responded to your PM. |
任何人都可以确认这个问题(CR)是否在2016.3解决了?
以上来自于谷歌翻译 以下为原文 Can anyone confirm if this issue (CR) was resolved in 2016.3? |
你好@ jsmithsrc
不,CR937716尚未修复。 你是否遇到过这个问题? 请打开一个新主题并包含合成后利用率报告和错误消息详细信息。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @jsmithsrc No, the CR 937716 is not yet fixed. Are you running in to this issue? Please open a new thread and include post synthesis utilization report and error message details. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 09:43 , Processed in 1.057149 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
13070
