电子发烧友论坛|
你好,我有一段时间前由synplify生成的现有edif文件(.edf)。
我想在这个文件上运行翻译后模拟。 我从一个新的ISE项目开始,并添加了我的.edf文件。 我没有.ucf。 我的新项目在ISE gui中看起来很正常。 当我在“来源”窗口中选择我的.edf文件并在进程窗口中单击“翻译”时,在几秒钟内我得到一个大的红色“X”表示translarte失败,但我没有收到任何错误消息或日志文件。 没有反馈我无法排除故障。 有任何想法吗? 需要.ucf吗? 我附上了我的ISE gui和我的目录的屏幕截图,显示了在尝试翻译过程后列出的文件。 以上来自于谷歌翻译 以下为原文 hello, i have an existing edif file (.edf) generated by synplify some time ago. i would like to run post-translate simulations on this file. i started with a new ISE project and added my .edf file. i do not have a .ucf. my new project looks normal in the ISE gui. when i select my .edf file in the "sources" window and click "translate" in the processes window, within a few seconds i get a big red "X" indicating that translarte failed, but i receive no error messages nor log files. i have no way to troubleshoot without feedback. any ideas? is a .ucf required? i have attached a screenshot of my ISE gui and my directory showing the files listed after attempting the translate process. |
4个回答
我能够成功翻译我生成的新EDIF文件。
我想知道我是否无法翻译这个较老的版本,因为它是由旧版本的synplify生成的,而不是我目前正在使用的????? 以上来自于谷歌翻译 以下为原文 i am able to successfully translate newer EDIF files i have generated. i am wondering if i am unable to translate this older one becuase it was generated by an older version of synplify than what i am currently using????? |
嗨,哪个版本的ISE&
Synplify您遇到了错误。请查看支持列表的ISE发行说明以缩小问题范围。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Which version of ISE & Synplify you were facing the errors. Please check with the ISE release notes for supported list to narrow down the issue.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我正在使用ISE 10.1和synplify 9.6.2,它们可以正常工作。
当我使用synplify 9.6.2生成edif时,我对翻译没有任何问题。 我有翻译问题的edif是由synplify8.2.0.P生成的,我没有。 以上来自于谷歌翻译 以下为原文 i am using ISE 10.1 and synplify 9.6.2, which do work fine togther. when i generate an edif with synplify 9.6.2 i have no problems with translate. the edif i am having problems translating was generated by synplify 8.2.0.P which i do not have. |
感谢更新。
请标记线程已关闭。 问候 Sikta 以上来自于谷歌翻译 以下为原文 Thanks for the update. Please mark the thread closed. Regards Sikta |
只有小组成员才能发言,加入小组>>
3147 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1197浏览 1评论
/9
GMT+8, 2025-12-13 17:57 , Processed in 0.545502 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4036
