电子发烧友论坛扫一扫,分享给好友
您好
我有一个模块的EDIF网表(由Vivado 2017.4中的第3方生成)。 我没有模块源verilog。 我有加密模块的行为模型,我有一个行为模型的测试平台。 行为模拟在Modelsim中运行。 行为模型为Modelsim提供了预编译的库。 我想用“结构”模型替换行为模型,我认为我可以通过“实现”在Vivado中生成 Vivado中的EDIF网表,并为Modelsim仿真编译输出。 所以我打开了一个带有EDIF网表的项目,并尝试通过实施来运行它。 我似乎无法在Viviado中实现EDIF a)为所有端口(大多数不是顶级IO端口)生成IBUF和OBUF,并快速耗尽所选设备的IO b)正在为未放置的顶级端口生成错误。 有没有办法绕过I / O BUF分配并避免与未放置的顶级IO相关的错误。 我已经附加了实现日志文件。 谢谢 财务巴雷 error_log.txt 20 KB 以上来自于谷歌翻译 以下为原文 HI I have an EDIF netlist (generated by 3'rd party in Vivado 2017.4) for a module. I do not have the the module source verilog. I have behavioral model for the module which is encrypted and I have a testbench for the behavioral model. The behavioral simulation is run in Modelsim. The behavioral model is given a pre-compiled library for Modelsim. I wanted to replace the behavioral model with "structural" model which I thought I could generate in Vivado by "implementing" the EDIF netlist in Vivado and compiling the output for Modelsim simulation. So I opened a project with the EDIF netlist in it and attempted to run this through implementation. I do not appear to be able to implement the EDIF in Viviado as it is a) Generating IBUF's and OBUF's for all ports (most of which are not Top level IO ports) and quickly runs out of IO for the selected device b) is generating errors for top level ports which are not placed. Is there a way of bypassing the I/O BUF assignments and avoiding errors associated with unplaced top level IO. I have attached the implementation log file. Thanks Finbarr |
3个回答
示例命令参考://////////////////// read_edif ./top.edflink_design -part xc7a100tftg256-2 -mode out_of_contextopt_designplace_designroute_design ///////////
//////// ThanksHong -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Example command for reference: //////////////////// read_edif ./top.edf link_design -part xc7a100tftg256-2 -mode out_of_context opt_design place_design route_design /////////////////// Thanks Hong------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
嗨,@ finbarrlong,由于模块是在OOC合成模式下生成的,因此实现也应该在OOC模式下运行,而不需要在设计中插入I / OBUF.ThanksHong
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, @finbarrlong , Since the module is generated under the OOC synthesis mode, implementation should also be run in the OOC mode without inserting I/OBUF in the design. Thanks Hong ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
//////// ThanksHong -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Example command for reference: //////////////////// read_edif ./top.edf link_design -part xc7a100tftg256-2 -mode out_of_context opt_design place_design route_design /////////////////// Thanks Hong------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 16:01 , Processed in 0.529354 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3591
