扫一扫,分享给好友
嗨,
在我的Vivado实现tcl脚本中,以下行导致错误: 设置SRC_PATH ./input ....... ...... #Input the netlist read_edif $ SRC_PATH / phif_top.edn 运行作业时出错: ************************************************** ************ 错误:[Common 17-69]命令失败:执行“read_edif $ SRC_PATH / phif_top.edf”时文件'/vivado/input/phif_top.edf'不存在(文件“./script/vivado.tcl”第30行) ************************************************** ************* 为什么该工具在'input'目录中搜索edf文件,后综合网表.edn存在? 同样在tcl脚本中,read_edif命令应该读取.edn文件而不是.edf文件? 我确保文件路径至少没有问题。 我很困惑。 预先感谢您对我们的支持。 感谢致敬, Amitra 以上来自于谷歌翻译 以下为原文 Hi, In my Vivado implementation tcl script the following line is causing an error: set SRC_PATH ./input ....... ...... #Input the netlist read_edif $SRC_PATH/phif_top.edn Error while running the job is: ************************************************************** ERROR: [Common 17-69] Command failed: File '/vivado/input/phif_top.edf' does not exist while executing "read_edif $SRC_PATH/phif_top.edf" (file "./script/vivado.tcl" line 30) *************************************************************** Why the tool is searching for an edf file while in the 'input' directory a post synthesis netlist .edn exists? Also in the tcl script the read_edif command should read .edn file and not a .edf file? I have made sure that there is no issue with file path atleast. I am confused. Thank you in advance for your support. Thanks and regards, Amitra |
4个回答
嗨@amitrasudan
你可以通过在解决后标记答案来关闭这个帖子吗? 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @amitrasudan Can you please close this thread by marking the answer as it is resolved? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
嗨阿米特拉,
您的EDIF文件位于/ vivado / input吗? 尝试在read_edif命令中给出EDIF文件位置的绝对路径,看看是否通过了。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi Amitra, Is your EDIF file located at /vivado/input ? Try giving the absolute path of EDIF file location in read_edif command and see if that passes. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨Deepika,
感谢回复。 路径有一些问题。 我纠正了它。 问候, Amitra 以上来自于谷歌翻译 以下为原文 Hi Deepika, Thanks for replying. There was some issue with the path. I rectified it. Regards, Amitra |
嗨@amitrasudan
你可以通过在解决后标记答案来关闭这个帖子吗? 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @amitrasudan Can you please close this thread by marking the answer as it is resolved? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2733 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
653浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
462浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
668浏览 0评论
1860浏览 0评论
GMT+8, 2024-9-30 04:59 , Processed in 1.082991 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
