电子发烧友论坛|
嗨,
我已经使用FPGA工作了几年,但我还没有意识到是否强制使用DCM复位。 我正在开发SP6,ISE14.7上的代码。 到目前为止,我曾经使用下面的电路 - 在VHDL中 - 有或没有检查和控制DCM_LOCK输出! 我真的很感激任何建议。 提前致谢, 侯赛因 以上来自于谷歌翻译 以下为原文 Hi, I have been working for some years with FPGAs, but I've not yet realized if using DCM reset is mandatory or not. I am developing my code on SP6, ISE14.7. Until now, I used to use below circuit - in VHDL - with or without checking and controlling DCM_LOCK output!. I would really appreciate any advice. Thanks in advance, Hossein |
2个回答
你好Hossein,
请访问以下链接:http://www.xilinx.com/support/troubleshoot/clocking_debug.htm 它会帮助你。 我的建议是使用RESET信号, 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello Hossein, Check this link: http://www.xilinx.com/support/troubleshoot/clocking_debug.htm It will help you. My suggestion is to use RESET signal, Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
另外,
有LOCKED信号和CLOCK_LOST信号(状态位)。 如果LOCKED丢失(变为假)或CLOCK LOST变为true,则应重置DCM。 通常,如果时钟在同一块板上(晶体ocsillator封装)并且它是如此可靠,并且检查LOCKED和CLOCK LOST是不必要的(因为它永远不会失锁,永远不会丢失时钟)。 但是,如果所有时钟都有可能出现故障或丢失,则需要在这些事件上重置DCM才能使DCM运行并再次锁定。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Additionally, There is the LOCKED signal, and CLOCK_LOST signal (status bits). If LOCKED is lost (becomes false), or CLOCK LOST becomes true, you should reset the DCM. Often if the clock is on the same board (crystal ocsillator package) and it is so reliable, and checking LOCKED and CLOCK LOST is not necessary (as it never loses lock, and never loses the clock). But, if there is any chance at all the clock could glitch, or be lost, then reseting the DCM on those events is required to get the DCM running and locked again. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:21 , Processed in 0.786402 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1217
