您好Xilinx社区,
有人能否就Spartan-6 FPGA是否需要设计中的上电复位电路给出明确的答案? 在附图中,我们的设计中有这个上电复位电路。 然而,我们遇到了电路问题,并决定在我们的设计中将它们全部移除。 我们只是想确保通过这样做,我们没有采用基于Spartan-6的设计的重要电路。 此上电复位电路的目的是在它监控的两个电源中的任何一个时提供复位信号:+ 3.3V和+ 1.2V或者FPGA本身的VCCINT和VCCO / VCCAUX电源低于a 某个门槛。 来自此上电复位电路的复位信号与FPGA固件中的DCM相连。 通过在我们的设计中移除此上电复位电路,我们基本上将DCM模块作为固件中的独立模块。 就我们已经看到Xilinx或Avnet的Spartan-6的几个评估卡的原理图而言,他们的设计中没有上电复位电路。 Xilinxs附带的示例Spartan-6原理图。 这是否意味着,在基于Spartan-6的设计中,真的不需要上电复位电路? 任何人都可以确认一下吗? 非常感谢你。 最好的祝福, - 王牌 上电复位CIRCUIT.pdf 175 KB xtp067_sp605_schematics.pdf 1305 KB 以上来自于谷歌翻译 以下为原文 Hi Xilinx Community, Can somebody please give a definitive answer to whether Spartan-6 FPGA's requires a Power On Reset circuit in the design? In the attached schematics, we have this Power On Reset circuit in our design. However we have encountered issues with the circuit and have decided to remove it all together in our design. We just want to make sure that by doing this, we are not taking out an important circuit of a Spartan-6 based design. The purpose for this Power On Reset circuit is that it provides a reset signal in the event that any of the two power supplies it monitors: +3.3V and +1.2V or the VCCINT and VCCO/VCCAUX supplies of the FPGA itself goes below a certain threshold. The reset signal coming from this Power On Reset circuit is tied to the DCM in the FPGA firmware. By removing this Power On Reset circuit in our design, we are basically making the DCM module as a standalone module in the firmware. In so far as we have seen of the schematics of several evaluation cards for Spartan-6 by Xilinx or by Avnet, there are no Power On Reset circuit in their designs. Example Spartan-6 schematics by Xilinxs attached. Does this mean then that, a Power On Reset circuit is NOT really needed in a Spartan-6 based design? Can anybody please confirm this? Thank you very much. Best Regards, -- ace POWER ON RESET CIRCUIT.pdf 175 KB xtp067_sp605_schematics.pdf 1305 KB |
3个回答
@ az77xilinxSpartan - 6内置POR电路。
查看UG394了解更多详情 http://www.xilinx.com/support/documentation/user_guides/ug394.pdf -------------------------------------------------- -------------------------------------------------- ----------------没有一个愚蠢的问题。 随意问,但快速搜索,以确保它还没有得到解答。 保持对话,获得Kudos和Accept Solution。 -------------------------------------------------- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @az77xilinx Spartan - 6 has a built in POR circuit. Check UG394 for more details http://www.xilinx.com/support/documentation/user_guides/ug394.pdf -------------------------------------------------------------------------------------------------------------------- There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered. Keep conversing, give Kudos and Accept Solution when you get one. -----------------------------------------------------------------------------------------------------------------------View solution in original post |
查看UG394了解更多详情 http://www.xilinx.com/support/documentation/user_guides/ug394.pdf -------------------------------------------------- -------------------------------------------------- ----------------没有一个愚蠢的问题。 随意问,但快速搜索,以确保它还没有得到解答。 保持对话,获得Kudos和Accept Solution。 -------------------------------------------------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @az77xilinx Spartan - 6 has a built in POR circuit. Check UG394 for more details http://www.xilinx.com/support/documentation/user_guides/ug394.pdf -------------------------------------------------------------------------------------------------------------------- There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered. Keep conversing, give Kudos and Accept Solution when you get one. ----------------------------------------------------------------------------------------------------------------------- |
嗨Gnarahar,
谢谢你的快速反应。 这确实非常有用,并且证实了基于Spartan-6的设计不需要外部POR电路。 再次感谢你。 最好的祝福, - 王牌 以上来自于谷歌翻译 以下为原文 Hi Gnarahar, Thank you for the quick response. This is indeed very helpful and confirms that there is no need for an external POR circuit for a Spartan-6 based design. Thank you again. Best Regards, -- ace |
只有小组成员才能发言,加入小组>>
2169 浏览 7 评论
2610 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2082 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2197 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
430浏览 1评论
1529浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2180浏览 0评论
511浏览 0评论
1645浏览 0评论
GMT+8, 2024-4-29 00:07 , Processed in 1.062428 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
