扫一扫,分享给好友
你好
我使用l6480驱动双极步进电机。一切都很好电机运行良好,但过电流检测功能是不可预测的工作。我已被禁用此功能,然后电机工作正常,并且存在关于电流阈值的计算的混淆。在'AN4355应用笔记'中 写道,'IOCDth = VOCDth×Rds(ON)'与l6480数据表的说法相矛盾,后者说'L6480测量每个半桥的负载电流,检测VDS电压所有功率MOSFET(图12)。当任何VDS电压超过设定的阈值时'。我想了解这个OCD功能。 以上来自于谷歌翻译 以下为原文 hello I am driving bipolar stepper motor using l6480. everything is fine motor is running excellent but the over current detection feature is working unpredictably. i have been disabled this feature then motor is working good, and there is confusion about the calculations of current threshold. in 'AN4355 Application note' it is written that 'IOCDth = VOCDth × Rds(ON)' which is contradicting the statement of datasheet of l6480, which says ' The L6480 measures the load current of each half-bridge sensing the VDS voltage of all the Power MOSFETs (Figure 12). When any of the VDS voltages rise over the programmed threshold'. i want to understand this OCD feature. |
5个回答
你好,
抱歉,这不是您问题的正确位置,请尝试在正确的论坛中移动它。 帕特里齐亚 以上来自于谷歌翻译 以下为原文 Hello, sorry but this is not the correct place for your question, try to move it in the correct forum. Patrizia |
发生过电流错误时?在某些情况下可能由于电机的电压尖峰,所以合适的缓冲电路可能会有所帮助。
以上来自于谷歌翻译 以下为原文 when a over current error happens? in some cases in could because of voltage spikes of motor, so a suitable snubber circuit could helps. |
你好对不起
它的错误是Patrizia bellitto。 以上来自于谷歌翻译 以下为原文 Hello sorry Its by mistake Patrizia bellitto. |
谢谢Ehsan Daneshvar
我对应用笔记中写的等式感到困惑。如上所述。 以上来自于谷歌翻译 以下为原文 Thanks Ehsan Daneshvar I m confused about the equation written in application note. Which is described above. |
请详细说明我方程的哪一部分不清楚? ..当你选择合适的功率MOSFET时。 MOSFET具有特定值RdsOn。例如关于IRFP250,该值为0.085欧姆..(当mosfet完全导通时)..因此,漏极到源极的电阻为0.085欧姆...通过读取漏极电压来源和根据OHM定律,您可以计算当前值。
所以根据应用笔记和数据表,你应该选择正确的阈值。 以上来自于谷歌翻译 以下为原文 please say me exactly what part of that equation is not clear ? .. when you choose a suitable Power MOSFET . that MOSFET has a specific value of RdsOn .for example about IRFP250 this value is 0.085 Ohm .. ( when mosfet is Completely On ) .. so it resistance of Drain to Source is 0.085 Ohm .. by reading the voltage of Drain to source and according to OHM law you can calculate the current value .. so according to application note and datasheet you should select correct threshold . |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 03:37 , Processed in 1.348413 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2585
