我目前遇到一个问题,我无法让L6480设备进行通信 - 我认为这可能是由于设备启动故障,但我希望有人可以提供帮助!
我附上了电路图的简化版本,概述了我在设计中所做的电源连接 - 如果我在电源连接上犯了任何错误,请告诉我!主机设备是一个8位Atmel AVR设备(ATmega32A),我正在使用+ 5V逻辑和+ 24V的电机电源。 我测量了电源引脚上的电压: VS - + 24V VBOOT - + 24V VSREG - + 24V VCC - + 2V5(!?) VCCREG - + 3V3 VREG - + 3V3 VDD - + 5V 我认为器件仍然处于'上电'状态,因为VCC低于数据表第6.1节中规定的最小值,并且来自OSCOUT引脚的2MHz信号既不是方波也不是正弦波。假设它会是? 我附上了示波器实际信号的图像,显示了我得到的波形。 任何反馈将不胜感激!!! #spi #power-up #cspin#l6480 以上来自于谷歌翻译 以下为原文 I'm currently experiencing a problem in which I cannot get the L6480 device to communicate - I think this may be due to a device power up fault but I was hoping someone on here could help! I've attached a simplified version of the circuit diagram, outlining the power connections that I've made in my design - if I've made any mistakes with the power connections then please let me know! The host device is an 8 bit Atmel AVR device (ATmega32A), and I'm working with +5V logic and a motor supply of +24V. I measured the voltages on the power pins to be: VS - +24V VBOOT - +24V VSREG - +24V VCC - +2V5 (!?) VCCREG - +3V3 VREG - +3V3 VDD - +5V I think the device is still in 'power-up' condition as VCC is below the minimum as stated in section 6.1 of the datasheet, and also the 2MHz signal coming from the OSCOUT pin is neither a square wave or a sine wave which I would have assumed it would be? I've attached an image of the actual signal from an oscilloscope which shows the waveform that I'm getting. Any feedback will be greatly appreciated!!! #spi #power-up #cspin #l6480 |
2个回答
STBY / RESET引脚现在由微控制器驱动为高电平但我仍然遇到同样的问题。我应该在OSCOUT引脚上看到什么样的波形?
以上来自于谷歌翻译 以下为原文 The STBY/ RESET pin is now being driven high by the microcontroller but I'm still having the same problems. What sort of waveform should I be seeing on the OSCOUT pin? |
OSCOUT波形是一系列频率为2 MHz的脉冲(占空比不是50%)。
以上来自于谷歌翻译 以下为原文 The OSCOUT waveform is a series of pulses with a frequency of 2 MHz.(the duty cycle is not 50%). |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2465 浏览 1 评论
3162 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1727 浏览 1 评论
3549 浏览 6 评论
5912 浏览 21 评论
886浏览 4评论
1264浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
529浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1247浏览 3评论
1301浏览 3评论
GMT+8, 2024-10-4 15:17 , Processed in 1.312461 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
