电子发烧友论坛|
大家好,我在PNA-X上有一个设置,它有多个窗口,并且在这些窗口中有多个跟踪。
使用A.09.80.03和A.09.80.15固件进行测试时,我注意到以下随机行为。 当我双击窗口中的空白区域进行放大然后重复该操作以缩小时,每隔一段时间,该窗口中活动跟踪的参考级别将突然变为某个随机值,从而导致跟踪 显示移位,有时离开显示区域。 问题是间歇性的,但一旦发生,它在放大/缩小窗口时总是会改变,尽管我将它改回到正确的水平。 我使用PNA-X的操作员也注意到了这个问题。 并且它没有本地化为1个特定的pna-x,因为它发生在我们拥有的3个pna-x上。 (与他们运行相同的A.09.80.15固件的共同主题)。 我希望其他人可以确认这种行为,并且问题可以解决。 另外,只是想提一下我见过的另一个类似的随机行为是某些窗口的跟踪标记显示会从x = 10,Y = 10的默认值随机偏移到某个值,例如x = 1, y = 1或x = 1,y = 10,或x = 10,y = 1和其他组合。 我在A.09.42.XX固件中看到的这种行为,或者当引入了能够移动迹线的特征时。 每当我回忆起.csa文件时,这都是随机发生的。 谢谢,rok编辑:rok于2012年12月13日下午7:15添加了一些pdf示例附件,以显示所描述的行为。编辑:rok于2012年12月13日下午7:17 12_13_2012-参考级别从26更改为153。 pdf28.1 KB 以上来自于谷歌翻译 以下为原文 Hi All, I have a setup on the PNA-X which has multiple windows and within those windows have multiple traces. I noticed the following random behavior when testing with the A.09.80.03 and A.09.80.15 firmware. When I am double-clicking onto a blank area within a window to zoom in and then repeating that action to zoom out, every so often, the reference level for the active trace within that window would suddenly change to some random value, causing the trace display to shift and sometimes off the display area. The problem is intermittent, but once it happens, it will always change when zooming in/out of that window, despite my changing it back to the right level. My operators using the PNA-X also has noticed this problem as well. And it is not localized to 1 particular pna-x, since it is happening on 3 pna-x's we have. ( with the common theme that they are running the same A.09.80.15 firmware). I am hoping someone else can confirm this behavior and that the problem can be resolved. Also, just wanted to mention that another similar random behavior that I've seen is the marker display of the traces for some windows would randomly shift from the default value of x=10, Y=10 to some value such as x=1,y=1 or x=1,y=10, or x=10,y=1 and other combinations. This behavior I have seen since A.09.42.XX firmware or when that feature of being able to move the traces around was introduced. This happens randomly whenever I'm recalling a .csa file. Thanks, rok Edited by: rok on Dec 13, 2012 7:15 PM Added some pdf examples attachments to show the behavior described. Edited by: rok on Dec 13, 2012 7:17 PM 附件 |
3个回答
你确定你不小心双击Y轴标签吗?
这将导致活动迹线的自动缩放。 它没有完全解释这个问题,但它可能是一个线索。 无论如何,我们很难复制这个。 也许你的设置的状态文件(对于每个问题)可能有帮助......或任何其他有助于我们复制它的信息。 正如我经常说的......如果我们可以复制它,我们可以解决它。 通常复制部分是最难的。 以上来自于谷歌翻译 以下为原文 Are you sure you are not accidentally double clicking on the Y axis labels? That would cause an autoscale of the active trace. It doesn’t fully explain the problem, but it might be a clue. In any case, we are having a hard time duplicating this. Maybe a state file of your setup (for each issue) might help....or any other information that would help us duplicate it. As I always say...if we can duplicate it, we can fix it. Usually the duplication part is the hardest. |
您好jvall,我已经通过电子邮件向您发送.sta文件,基于您发送给我的PM消息回复。
但是,我不确定它是否会先于你,因为它大约是一个20兆字节的附件。 使用我发给你的那个文件,我能够通过更改参考级别来复制之前描述的问题。 如果您还需要其他任何帮助来解决问题,请与我们联系。 最好的问候,rokEdited:rok于2013年1月2日下午1:06 以上来自于谷歌翻译 以下为原文 Hello jvall, I have already sent you the .sta file via email, based on the PM message reply you sent me. However, I'm not sure if it successively got to you or not, since it was about a 20Megabyte attachment. With that file I sent you, I was able to replicate the problem described before with the changing reference level. Let me know if you need anything else to help troubleshoot the problem. Best regards, rok Edited by: rok on Jan 2, 2013 1:06 PM |
蓝色冰汐 发表于 2019-4-30 14:11 对不起。 是的,我确实得到了这个文件,但我们已经关闭了将近两个星期,今天又回来工作了。 我还没有调查过,但我会在早上尝试。 合资公司 以上来自于谷歌翻译 以下为原文 I am sorry. Yes, I did get the file but we have been closed for almost two weeks and just got back to work today. I have not yet investigated this, but I will try in the morning. JV |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:51 , Processed in 0.909339 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1890
