电子发烧友论坛|
亲爱的先生,
我正在尝试在Spartan 6中使用PLL。我有Nexys 3板和Lx16封装CSG324封装。 参考手册说它有2个CMT,即4个DCM和2个PLL。 但每当我想从新的源向导中插入新的源代码并选择IP内核时,我会尝试添加PLL,因为设备中没有可用的收费。 在兼容设备列表中的Vertex组。 是否由于我有30天的节点锁定评估许可证? 请帮忙。 问候 Dipankar 以上来自于谷歌翻译 以下为原文 Dear Sir, I am trying to use PLL in Spartan 6. I have Nexys 3 Board with Lx16 Package CSG324 Package. The reference manual says it has 2 CMT's i.e. 4 DCM's and 2 PLL's. But Whenever I want to insert a new source from the new source wizard and I select IP core and I try to add PLL the toll says not available in your device. In compatible device lists Vertex group. Is it due to I have a 30 days node Locked Evaluation license? Please Help. Regards Dipankar |
4个回答
你能发贴许可证文件吗?谢谢
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Could you post you license file? Thanks------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好
您应该使用spartan6的时钟向导来使用PLL和DCM,如下面的快照所示。 旧的PLL和DCM向导不适用于6和7系列设备。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi you should use the clocking wizard for spartan6 to use the PLL and DCM's as shown in the below snapshot. THe old PLL and DCM wizard's are not applicable for 6 and 7 series devices. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
嗨,
这不应该是许可证问题,因为评估许可证不应该停止添加IP内核。 您使用的是哪个版本的工具? 尝试使用独立的coregen工具,然后将源单独添加到主设计中并进行检查。 独立核心应报告该核心支持的所有设备。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi,
Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
dipankar123sil写道:
亲爱的先生, 我正在尝试在Spartan 6中使用PLL。我有Nexys 3板和Lx16封装CSG324封装。 参考手册说它有2个CMT,即4个DCM和2个PLL。 但每当我想从新的源向导中插入新的源代码并选择IP内核时,我会尝试添加PLL,因为设备中没有可用的收费。 在兼容设备列表中的Vertex组。 是否由于我有30天的节点锁定评估许可证? 不要使用向导。 阅读S6 HDL库指南并实例化PLL。 这很容易。 提供了一个模板。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 dipankar123sil wrote:Don't use the wizard. Read the S6 HDL library guide and instantiate the PLL. It's easy. A template is provided. ----------------------------Yes, I do this for a living. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4108 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1202浏览 1评论
/9
GMT+8, 2025-12-15 11:18 , Processed in 0.898680 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1545
