电子发烧友论坛|
我尝试使用“clockin向导”在Spartan6中使用PLL
我们可以指定的2个参数是输入和输出抖动。 但是与构建PLL的常用参数有什么关系: 1)输入捕获范围,定义输入频率的窗口:是输入抖动吗? 2)滤波器的带宽,它定义了环路的速度:它是输出抖动吗? 谢谢你的帮助 以上来自于谷歌翻译 以下为原文 I try to use a PLL in a Spartan6 by using the "clockin wizard" and the 2 parameters we can specify are the input and output jitters. But what are the relations with the usual parameters to build a PLL: 1) the input capture range, which defines the window of the input frequency : is it the input jitter? 2) the bandwidth of the filter, which defines the speed of the loop : is it the output jitter ? thanks for your help |
1个回答
S,
PLL具有非常宽的输入捕获范围,即使不是数百MHz,也可以是数十甚至数十。 输入抖动非常重要,因为它太高,PLL可能会失锁,请参见数据手册。 PLL的“极点”约为300 KHz,并且还具有约1 MHz的另一个可选极点。 这些是根据输入频率,M和D值自动选择的。 你为什么在乎? PLL将消除高频抖动(相位噪声)但除了跟踪较慢的变化率(低频抖动)之外无法做任何事情。 极需要一个电容器,不能做得太大(太多=太贵)。 同样,PLL与商用扩频时钟源兼容,通过在窄范围内扫描频率来降低EMI / RFI,然后再返回(通常是30KHz左右的三角形FM)。 您希望PLL跟踪SS时钟(跟随它)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 s, The PLL has a very wide input capture range, many many tens if not hundreds of MHz. The input jitter is important as if it is too high, the PLL may lose lock, See the data sheet. The "pole" for the PLL is at about 300 KHz, and also has another selectable pole at about 1 MHz. These are selected automatically based on the input frequency, M and D values. Why do you care? The PLL will remove high frequency jitter (phase noise) but can not do anything but track slower rates of change (low frequency jitter). The pole requires a capacitor, which can not be made very large (too much are=too expensive). As well, the PLL is compatible with commercial spread spectrum clock sources which reduce EMI/RFI by sweeping their frequency across a narrow range, and back again (usually triangular FM at 30 KHz or so). You want the PLL to track the SS clock (follow it). Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:56 , Processed in 0.558801 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2713
