电子发烧友论坛|
我确实遇到了一个我想解决的问题。
这更像是Vivado的实现问题。 我正在尝试使用ILA内核和探针将调试内核添加到我的设计中。 执行设计后,我收到以下错误: [Chipscope 16-119]实现调试核心dbg_hub失败。 错误:[Chipscope 16-111] Vivado Analyzer功能的许可证检查失败 - 中止调试核心实施。 许可证文件显示“到期日期”是永久性的,但“版本限制”是2016.05。 我附上了“环境报告”,其中显示分析仪和Chipscope的版本超出了版本限制范围。 考虑到我们有永久许可,我该如何解决这个问题? 环境报告.docx 37 KB CDebug Error.docx 161 KB 以上来自于谷歌翻译 以下为原文 I do have an issue that I am trying to resolve. This is more of an implementation issue with Vivado. I am attempting to add debug cores to my design with ILA cores and probes. Upon implementation of the design I received the following error: [Chipscope 16-119] Implementing debug core dbg_hub failed. ERROR: [Chipscope 16-111] License check failed for Vivado Analyzer Feature - aborting debug core implementation. The license file shows that the "Expiration Date" is permanent, though the "Version Limit" is 2016.05. I have attached the "environmental report" also that shows the version of the Analyzer and Chipscope are outside the version limit range. How can I resolve this issue, considering we have a permanent license? environment report.docx 37 KB CDebug Error.docx 161 KB |
4个回答
嗨@vharpernpa,
我很欣赏日志文件。 你在运行什么版本的工具? 如果您运行的时间晚于Vivado 2016.1,则许可证将不兼容,并且不支持分析仪功能。 https://www.xilinx.com/support/answers/33770.html 谢谢, 德文 - 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @vharpernpa, I appreciate the log files. What version of the tools are you running? If you are running anything later than Vivado 2016.1 then the license will not be compatible and not support the analyzer feature. https://www.xilinx.com/support/answers/33770.html Thank you, Devin View solution in original post |
嗨@vharpernpa,
我很欣赏日志文件。 你在运行什么版本的工具? 如果您运行的时间晚于Vivado 2016.1,则许可证将不兼容,并且不支持分析仪功能。 https://www.xilinx.com/support/answers/33770.html 谢谢, 德文 - 以上来自于谷歌翻译 以下为原文 Hi @vharpernpa, I appreciate the log files. What version of the tools are you running? If you are running anything later than Vivado 2016.1 then the license will not be compatible and not support the analyzer feature. https://www.xilinx.com/support/answers/33770.html Thank you, Devin |
谢谢回复。
15.2中的工具版本。 我去了另一台笔记本电脑并复制了许可证文件,这似乎解决了这个问题。 我非常感谢你在此事上的时间和考虑。 以上来自于谷歌翻译 以下为原文 Thanks for the reply. The version of the tool in 15.2. I went to another laptop and copied the license file over, and that seems to have resolved the issue. I really appreciate your time and consideration on this matter. |
你好@vharpernpa,
非常感谢让我们知道,我们很高兴看到您的问题现在得到解决。 在您的问题得到解决后,请将适当的回复标记为已接受的解决方案(有关详细信息,请访问此处:https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions) ,那么话题就可以完成了。 感谢您的帮助。 提前谢谢,祝你有个美好的一天。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @vharpernpa, Thanks a lot for letting us know and we are glad to see your issue is resolved now. As your issue is solved, please mark an appropriate response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so the topic can be completed then. We appreciate your help. Thanks in advance and have a great day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 10:21 , Processed in 1.066909 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1922
