[Chipscope 16-119]实现调试核心u_ila_0 failed.ERROR:无法为u_ila_0生成核心。
中止IP生成操作。 错误:[Chipscope 16-218]尝试从IP缓存管理器创建或获取缓存实例时发生错误:“生成DCP文件时出现问题” 在http://www.xilinx.com/support/answers/60856.htmlthread上尝试了解决方案。但仍然遇到问题。 使用2016.2版本。 以上来自于谷歌翻译 以下为原文 [Chipscope 16-119] Implementing debug core u_ila_0 failed. ERROR: Could not generate core for u_ila_0. Aborting IP Generation operation. ERROR: [Chipscope 16-218] An error occurred while trying to create or get a cached instance from the IP cache manager: "Problem generating DCP file" Have tried the solution on this http://www.xilinx.com/support/answers/60856.html thread.But still getting the issue. Using 2016.2 version. |
1个回答
@ hulk789,
如果您正在使用Windows操作系统,您是否可以尝试减少项目目录路径,看看它是否有助于您已指出的AR中已提到的内容。 还要确保项目路径中没有特殊字符。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @hulk789, If you are using windows OS, Can you try reducing the project directory path and see if it helps which is already mentioned in AR you have pointed. Also make sure there are no special characters in the project path. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 17:55 , Processed in 0.724995 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2764
