扫一扫,分享给好友
我是Oregon Tech的学生,使用Vivado 2015.2进行高级VHDL。
我在我的笔记本电脑上安装了Vivado,可以在任何地方进行设计和模拟,但除非我在校园网络上,否则我无法生成比特流来编程我的设备。 我得到的错误是: [Chipscope 16-119]实现调试核心dbg_hub失败.ERROR:[Chipscope 16-111] Vivado Analyzer功能的许可证检查失败 - 中止调试核心实现...... 为什么这在校园网络上运行,但我无法在家中工作? 有没有可以解决这个问题,让我可以在家里建造? 技术支持拒绝提供帮助,而是指向我。 以上来自于谷歌翻译 以下为原文 I'm a student at Oregon Tech taking Advanced VHDL using Vivado 2015.2. I have Vivado installed on my laptop, and can design and simulate anywhere, but I cannot generate a bitstream to program my device unless I am on the campus network. The error I get is: [Chipscope 16-119] Implementing debug core dbg_hub failed. ERROR: [Chipscope 16-111] License check failed for Vivado Analyzer feature - aborting debug core implementation... Why does this work on the Campus network, but I cannot get it to work from home? Is there a work around for this to allow me to build from home? Tech support has declined to offer assitance and pointed me here instead. |
8个回答
你好@ chaosmstr
你有哪个许可证? 请在Vivado TCL控制台中运行以下命令并与我共享输出? report_environment -file /xinfo.txt 以上来自于谷歌翻译 以下为原文 Hi @chaosmstr Which license you are having? Please run the below command in Vivado TCL console and share the output with me? report_environment -file |
那么,给出的命令不起作用。
我假设它应该创建一个文件? 编辑命令不会创建文件。 我已经尝试编辑到c:/xylinx/xinfo.txt 我已经尝试将其设置为我的桌面。 没有创建文件,但控制台看起来像是构建了一个文件。 NFO:[Common 17-635]现在获取报告信息。 这可能需要一些时间:[通用17-633]获取系统信息...信息:[通用17-632]获取软件环境信息...信息:[通用17-629]获取Vivado首选项...信息 :[Common 17-630]获取安装信息... INFO:[Common 17-628]获取DLL信息... INFO:[Common 17-631]获取许可证信息... INFO:[Common 17-634] Done 获取报告信息.report_environment:Time(s):cpu = 00:00:00; 逝去了= 00:00:05。 记忆(MB):峰值= 1422.516; 增益= 0.000 以上来自于谷歌翻译 以下为原文 Well, the command as given doesn't work. I assume it's supposed to create a file? Editing the command does not create a file. I've tried editing I've tried setting it to my desktop. No file is created, but the console looks like it built one. NFO: [Common 17-635] Now fetching report information. This may take some time. INFO: [Common 17-633] Fetching system information... INFO: [Common 17-632] Fetching software environment information... INFO: [Common 17-629] Fetching Vivado preferences... INFO: [Common 17-630] Fetching installation information... INFO: [Common 17-628] Fetching DLL information... INFO: [Common 17-631] Fetching license information... INFO: [Common 17-634] Done fetching report information. report_environment: Time (s): cpu = 00:00:00 ; elapsed = 00:00:05 . Memory (MB): peak = 1422.516 ; gain = 0.000 |
嗨@ chaosmstr,
请在Vivado Tcl控制台中尝试以下命令。 report_environment 它将打印信息。 请将这些内容复制到文件中并将其附加到此主题。 谢谢和问候,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @chaosmstr, Please try the following command in Vivado Tcl console. report_environment It will print the informations. Please copy those contents to a file and attach it with this thread. Thanks and Regards, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好@ chaosmstr,
从输出报告中,您已在系统上成功安装了Vivado WebPack许可证,但它不允许您使用逻辑分析器功能。 您可以查看以下链接 http://www.xilinx.com/products/design-tools/vivado/vivado-webpack.html 要使用此功能,您可以尝试使用免费的30天评估许可证(生成和激活过程类似于WebPack),或者您可以购买Design Edition / System Edition许可证。 请联系您的FAE以了解有关此许可证的更多详细信息http://www.xilinx.com/about/contact/authorized-distributors.html 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @chaosmstr, From the output report, you have installed Vivado WebPack license successfully on your system but it won't allow you to use logic analyzer feature. You can check below link http://www.xilinx.com/products/design-tools/vivado/vivado-webpack.html To use this feature, you can try using Free 30-day evaluation license (generation and activation process is similar to WebPack) or you can purchase Design Edition/System Edition license. Please contact your FAE to know further details regarding this license http://www.xilinx.com/about/contact/authorized-distributors.html Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
好的...但是为什么它允许我在校园网络上运行该功能?
30天免费赠品很棒,除了我还有8周的课时。 以上来自于谷歌翻译 以下为原文 Ok... but why would it allow me to run that feature while on the campus network? A 30 day freebie is great, except I have 8 more weeks of class. |
你好@ chaosmstr,
是的,它应该工作,因为它将是节点锁定许可证。 通过节点锁定,我的意思是它将被锁定到系统的网络接口卡ID(或以太网MAC地址)或C:驱动器序列号(卷号)。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @chaosmstr, Yes it should work because it will be node-locked license. By node-locked, I mean it will be locked to Network Interface Card ID (or Ethernet MAC address) or C: drive serial number (Volume number) of your system. Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
好吧,我很困惑。
什么应该工作,因为它的节点被锁定了? webpack许可证? 逻辑分析仪? 30天的试用期? 我之所以感到困惑是因为当我连接到校园网络时,分析仪工作,但不是在我在家时。 系统是相同的,MAC地址或驱动器序列没有改变,只有它附加的网络。 以上来自于谷歌翻译 以下为原文 ok, Im confused. What should work because it's node locked? The webpack license? The logic analyzer? The 30 day trial? My confusion comes because the analyzer works while I am attached to the campus network, but not while I'm at home. The system is the same, the MAC address or drive serial hasn't changed, only what network it's attached to. |
只有小组成员才能发言,加入小组>>
2222 浏览 7 评论
2645 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2127 浏览 9 评论
3197 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2254 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
497浏览 1评论
1580浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2221浏览 0评论
547浏览 0评论
1716浏览 0评论
GMT+8, 2024-7-6 00:59 , Processed in 1.784334 second(s), Total 92, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
