电子发烧友论坛扫一扫,分享给好友
我正在使用SDK将vivado 2014.2系统版重新安装到win 10笔记本电脑上。
它已经运行了一年多,然后它在生成比特流时挂断了。 我尝试了几次重新运行,每次都出现同样的问题。 所以我卸载了整个vivado 2014.2。 安装顺利进行,直到尝试完成安装,然后尝试“生成已安装的设备列表”。 它每次都失败了。 在安装日志中,这是记录的内容: 2016-05-25 14:33:02,061调试:o.k:? - 无法运行GenerateDeviceFileListWin_SCRIPT,退出代码:1073807364,stdout :, stderr:特定于应用程序的初始化失败:失败消息:特定于应用程序的初始化失败: 任何帮助,将不胜感激。 谢谢, 约翰 以上来自于谷歌翻译 以下为原文 I am re-installing vivado 2014.2 system edition with SDK onto win 10 laptop. It had been working fine for over a year, and then it hung up while generating a bitstream. I attempted several re-runs and the same problem occured each time. So I un-installed the entire vivado 2014.2. The installation goes well until it is attempting to finalize the installation, and it attempts "Generating installed device list". And it fails each time. In the install log this is what is recorded: 2016-05-25 14:33:02,061 DEBUG: o.k:? - Unable to run GenerateDeviceFileListWin_SCRIPT, exit code: 1073807364, stdout: , stderr: application-specific initialization failed: failure msg: application-specific initialization failed: Any help would be appreciated. thanks, John |
4个回答
嗨@johnvandoren
查看此答复记录:http://www.xilinx.com/support/answers/60111.html 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @johnvandoren Check this answer record: http://www.xilinx.com/support/answers/60111.html Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我已尝试过,它就像Vivado安装程序在我复制到第一篇文章中的安装日志文件中报告一样失败。
我发现了其他几个AR,但他们的建议都没有帮助 以上来自于谷歌翻译 以下为原文 I have attempted that and it fails just as the Vivado installer reports in the install log file that I copied into the first post. I found several other AR's, but none of their suggestions help either |
你好@ johnvandoren
运行此命令后共享输出: Vivado 2014.1 bin vivado.bat -nolog -nojournal -mode batch -source .xinstall Vivado_2014.1 scripts xlpartinfo.tcl -tclargs Vivado 2014.1 data parts installed_devices.txt 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @johnvandoren Share the output after running this command: Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
我上周尝试了这个命令,错误日志说明了: C: Xilinx Vivado 2014.2 bin vivado.bat [-nolog,-nojournal,-mode,batch,-source,C: Xilinx .xinstall Vivado_2014.2 scripts xlpartinfo.tcl,-tclargs, C:赛灵思 Vivado 2014.2 数据份 installed_devices.txt] 特定应用程序初始化失败 昨天我放弃了尝试解决这个问题,并重新加载了MS win8和vivado 2014.2。 Vivado工作。 升级到win10(这是我有一年的时间,并且与Vivado 2014.2一起工作得很好),Vivado仍然有效。 所以我都准备好了。 谢谢, 约翰 以上来自于谷歌翻译 以下为原文 Hi, I tried that command last week, and the error log stated: C:XilinxVivado2014.2binvivado.bat [-nolog, -nojournal, -mode, batch, -source, C:Xilinx.xinstallVivado_2014.2scriptsxlpartinfo.tcl, -tclargs, C:XilinxVivado2014.2datapartsinstalled_devices.txt] application-specific initialization failed Yesterday I gave up on trying to fix this and reloaded MS win8 and vivado 2014.2. Vivado works. Upgraded back to up to win10 (which is what I had for a year and worked just fine with Vivado 2014.2) and Vivado still works. So I am all set. thanks, John |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 22:11 , Processed in 1.667185 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3719
