电子发烧友论坛扫一扫,分享给好友
你好,
我正在尝试安装Vivado 2015.1。 我的操作系统是Debian Jessie。 当我输入./xsetup开始安装时,我收到以下错误: 错误:32位平台不支持此安装 然后我用uname来检查 - 操作系统的架构是X86_64,换句话说就是64位架构。 我知道Debian不在兼容性列表中,但之前我在Debian Wheezy中安装了Vivado 2014.4而没有任何问题。 有什么建议吗? 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I am trying to install Vivado 2015.1. My operating system is Debian Jessie. When I enter ./xsetup to start installation I get the following error: ERROR: This installation is not supported on 32 bit platforms Then I check with uname - m the operating system's architecture which is X86_64 in other words 64 bit architecture. I know that Debian is not in the compatibility list but previously I had Vivado 2014.4 installed in Debian Wheezy without any issues. Are there any suggestions? Thank you! |
6个回答
您好,请查看发行说明中的以下几行“从Vivado 2015.1开始,32位操作系统和应用程序支持已被删除,用于所有设计输入和实施流程。”
此外,建议使用支持的操作系统.http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf(第11页) 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello, Please check below lines from release notes "Beginning with Vivado 2015.1, 32-bit Operating System and application support has been removed for all design entry and implementation flows." Also It is recommended to use supported operating system. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf (page #11) Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
此外,建议使用支持的操作系统.http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf(第11页) 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, Please check below lines from release notes "Beginning with Vivado 2015.1, 32-bit Operating System and application support has been removed for all design entry and implementation flows." Also It is recommended to use supported operating system. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf (page #11) Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
谢谢你的回复!似乎我有一个32位操作系统!
以上来自于谷歌翻译 以下为原文 Thank you for your reply! Then it seems that I have a 32 bit operating system! |
嗨,我在Debian GNU / Linux 64位(内核3.18的不稳定分支)上遇到了同样的问题。
我检查了“uname -a”,输出是“x86_64 GNU / Linux”。 目前我正在运行Vivado 2014.4,“关于Vivado ......”显示“Vivado v2014.4(64位)”。 显然这是一个64位操作系统,2014.4就可以了。 有什么建议? 问候 延斯。 以上来自于谷歌翻译 以下为原文 Hi, I am facing the same problem on Debian GNU/Linux 64-bit (unstable branch with kernel 3.18). I checked with "uname -a" and the output is "x86_64 GNU/Linux". Currently I am running Vivado 2014.4 just fine and "About Vivado..." shows "Vivado v2014.4 (64-bit)". So obviously this is a 64-bit OS and 2014.4 was ok with that. Any proposals? Regards Jens. |
显然xsetup脚本使用“uname -i”,它在我的Arch linux安装上返回“unknown”。
但是如果你知道你有一个x86_64系统,你可以简单地注释掉xsetup文件中的检查,安装转到文件,它似乎也是vivado& vivado hls工作正常。 以上来自于谷歌翻译 以下为原文 Apparently the xsetup script uses "uname -i" which returns "unknown" on my Arch linux installation. But if you know that you have an x86_64 system, you can simply comment out the check in the xsetup file, installation goes file and it seems also that vivado & vivado hls work fine that way. |
那就对了。
在我的机器上“uname -m”返回“x86_64”,而“uname -i”返回“unknown”。 因此,可以解压缩安装程序并更改xsetup脚本或为此目的创建虚假的“uname -i”。 请参阅Debian关于此问题的讨论: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=655428 以上来自于谷歌翻译 以下为原文 That's right. On my machine "uname -m" returns "x86_64" whereas "uname -i" returns "unknown". So one can either uncompress the installer and change the xsetup script or create a fake "uname -i" for that purpose. Refer to the Debian discussion about this issue: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=655428 |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 01:06 , Processed in 0.790880 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7137
