电子发烧友论坛扫一扫,分享给好友
您好我们刚刚从Xilinx网站购买了Vivado许可证,我在VM上安装激活许可证时遇到同样的错误。
如何将许可证转换为基于证书的许可证? 我再也无法访问webcase了。谢谢.Bhavya 以上来自于谷歌翻译 以下为原文 Hi We just bought Vivado license directly from Xilinx web and I am getting same error installing activation license on VM. How can I get my license converted to certificate based license? I do not have access to webcase anymore. Thanks Bhavya |
1个回答
您好Bhavya,由于您无法访问webcase,我建议您联系离您最近的Xilinx分销商或Xilinx Sales,并要求他们联系Xilinx技术支持。
Xilinx销售代表:http://www.xilinx.com/company/contact/sales-reps.htm Xilinx分销商:http://www.xilinx.com/company/contact/auth-disti-table.htmXilinx Technical Supoort将帮助您将基于激活的许可转换为基于证书的许可。注意:创建单独的软件始终是一个好习惯 发布您的查询/问题时的线程。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Bhavya, Since you do not have access to webcase, I suggest you to contact your nearest Xilinx distributors or Xilinx Sales and ask them to contact Xilinx Technical Support. Xilinx Sales Representatives: http://www.xilinx.com/company/contact/sales-reps.htm Xilinx Distributors: http://www.xilinx.com/company/contact/auth-disti-table.htm Xilinx Technical Supoort will help you to convert activation based license to certificate based license. Note: It is always good practice to create a separate thread when posting your query/issue. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:38 , Processed in 0.610481 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2350
