你好,
我尝试激活Vivado Webpack 2014.1。 Vivado License Manager - >加载许可证 - >激活许可证... - > Xilinx_License.xml 返回“无法将许可权限加载到可信存储” 你有什么想法? 电贺 以上来自于谷歌翻译 以下为原文 Hello, i try to activate Vivado Webpack 2014.1. Vivado License Manager -> Load License -> Activate License ... -> Xilinx_License.xml returns with "Unable to load License Rights into Trusted Storage" Do you have any ideas? Greets |
23个回答
添加到Vinay的建议......目前,Xilinx激活许可证生成器无法支持虚拟机。
如果尝试为VM生成许可证,则会出现以下错误。 错误:API函数60009失败,结果51412有与此问题相关的更改请求(CR#772376),暂定计划是在Vivado 2014.3版本中解决此问题。 在激活许可可用于虚拟机之前,如果需要使用虚拟机来提供浮动许可,请联系Xilinx销售或分销商,请求将您的许可权利从激活更改为基于证书的许可。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 To add to Vinay's suggestions... Currently the Xilinx activation license generator is not able to support virtual machines. And will give the following error if an attempt is made to generate a license for a VM. Error: API function 60009 failed, result 51412 There is a change request (CR#772376) associated with this issue and tentative plan is to fix this in Vivado 2014.3 release. Until activation licensing is available for virtual machines, if the use of a virtual machine is required to serve a floating license, contact Xilinx Sales or Distributors to request that your license entitlement be changed from Activation to Certificate based licensing. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
您好Greets,请尝试以下步骤:1。
打开命令提示符2。 导航到 Xilinx Vivado 2014.1 bin3。 运行命令:xlicclientmgr -p Xilinx_License.xml确保使用管理员权限打开命令提示符。尝试这些步骤并仍然出错,附上命令提示符的快照。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Greets, Try these steps: 1. Open Command prompt 2. Navigate to 3. run the command: xlicclientmgr -p Make sure to open command prompt using administrator privileges. Try out these steps and still errors out, attach a snapshot of command prompt. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
su root./xlicclientmgr -p Xilinx_License.xml 返回:“错误:API函数60009失败,结果51412 响应处理失败。处理响应时退出(4)错误。“ 电贺 以上来自于谷歌翻译 以下为原文 Hi, su root ./xlicclientmgr -p Xilinx_License.xml returns: "ERROR: API function 60009 failed, result 51412 Response processing failed. Exit(4) error when processing response." Greets |
我有同样的问题!
我尝试激活Vivado Webpack 2014.1。 Vivado License Manager - >加载许可证 - >激活许可证... - > Xilinx_License.xml 返回“无法将许可权限加载到可信存储” 如果我从vuppala尝试这个: 1.打开命令提示2。 导航到 Xilinx Vivado 2014.1 bin 3.运行命令:xlicclientmgr -p Xilinx_License.xml 返回: “错误:API函数60009失败,结果51412 响应处理失败。处理响应时退出(4)错误。“ 我能做什么! 以上来自于谷歌翻译 以下为原文 I have the same probles! i try to activate Vivado Webpack 2014.1. Vivado License Manager -> Load License -> Activate License ... -> Xilinx_License.xml returns with "Unable to load License Rights into Trusted Storage" if i try this from vuppala: 1. Open Command prompt 2. Navigate to 3. run the command: xlicclientmgr -p Response processing failed. Exit(4) error when processing response." what can i do! |
以上来自于谷歌翻译 以下为原文 3. run the command: xlicclientmgr -p |
响应处理失败。处理响应时退出(4)错误。“ 以上来自于谷歌翻译 以下为原文 "ERROR: API function 60009 failed, result 51412 Response processing failed. Exit(4) error when processing response." |
这里有人有成功解决这个问题吗?
买了一个Nexys4板来学习VHDL,因为这个许可的东西让它无法运行......顺便说一下,我在Mac上运行Vmware ... 以上来自于谷歌翻译 以下为原文 Anyone here had sucess working around this problem? Bought a Nexys4 board to learn VHDL and cant get it running because of this licencing stuff... I am running Vmware on a Mac by the way... |
嗨,正如我在之前的帖子中所提到的,因为您使用的是VM,所以请联系Xilinx销售或分销商,因为您正在使用VM.Thanks,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, As mentioned in my earlier post, contact Xilinx Sales or Distributors related to this issue since you are using VM. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
如果尝试为VM生成许可证,则会出现以下错误。 错误:API函数60009失败,结果51412有与此问题相关的更改请求(CR#772376),暂定计划是在Vivado 2014.3版本中解决此问题。 在激活许可可用于虚拟机之前,如果需要使用虚拟机来提供浮动许可,请联系Xilinx销售或分销商,请求将您的许可权利从激活更改为基于证书的许可。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 To add to Vinay's suggestions... Currently the Xilinx activation license generator is not able to support virtual machines. And will give the following error if an attempt is made to generate a license for a VM. Error: API function 60009 failed, result 51412 There is a change request (CR#772376) associated with this issue and tentative plan is to fix this in Vivado 2014.3 release. Until activation licensing is available for virtual machines, if the use of a virtual machine is required to serve a floating license, contact Xilinx Sales or Distributors to request that your license entitlement be changed from Activation to Certificate based licensing. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我们如何返回从未生成的激活许可证,以便将许可证转移到新主机?
我在我的VM上收到了“错误:API函数60009失败,结果51412”错误,现在想将licesen移动到另一台主机。 即使许可证从未安装到可信存储中,我是否可以创建返回请求? 以上来自于谷歌翻译 以下为原文 How can we return an activation license that was never generated so the license can be transfered to a new host? I recived the "Error: API function 60009 failed, result 51412" error on my VM and would now like to move the licesen to another host. Can I create a return request even though the license never installed into trusted storage? |
嗨,
您无法将未安装的许可证返回到可信存储中。 从错误消息中,我可以说您正在使用VM。 不支持VM。 有关更多信息,请参阅Vijay的帖子。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, You cannot return the license that was not installed into trusted storage. From the error message, I can say that you are using VM. VMs are not supported. See Vijay's post for more information. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
在VM中运行Xilinx工具的原因有很多种,但其中最主要的是Xilinx安装脚本在不受支持的Linux系统上的不稳定性。
RHEL仍然是唯一官方支持的Linux平台。 我出于其他原因在这里运行Xubuntu和Fedora开发内核。 无论它是什么,Windows仍然是安装脚本和USB驱动程序的黄金标准,而不仅仅是Xilinx工具。 从用户的角度来看,一切正常。 Windows的问题是你仍然需要类似Linux的工具来构建嵌入式Linux内核和启动映像。 Windows上的Cygwin和MinGW远远低于VM中的Linux。 我认为这里的问题是虚拟化NIC可以为许可系统带来的安全问题。 这里需要指出的是,有一些同样简单的方法可以将任意EUI-48分配给没有VM的接口。 拜托,我正在尝试用一个WebPack安装来教我的儿子在一个小型Zynq板上的嵌入式系统。 对于免费许可证,优雅简单的机器身份检查是否可以例外? 以上来自于谷歌翻译 以下为原文 The reasons to run Xilinx tools in a VM are many and varied, but chief among them has to be the flakiness of Xilinx install scripts on non-supported Linux systems. RHEL is still the only officially supported Linux platform. I run Xubuntu and Fedora development kernels here for other reasons. Whatever else it may be, Windows is still the gold standard for installation scripts and USB drivers, and not just for Xilinx tools. Everything just works, from the user perspective. The problem with Windows is you still need a Linux-like facility to build the embedded Linux kernel and boot images. Cygwin and MinGW on Windows are far inferior to Linux in a VM. I presume the issue here is the security concerns that a virtualized NIC can make for the licensing system. It needs to be pointed out here that there are equally simple ways to assign an arbitrary EUI-48 to an interface without a VM. Please, I'm trying to bring up a WebPack installation to teach my son about embedded systems on a small Zynq board. Can't an exception be made in the elegantly simple machine identity check be made for the free licenses? |
这真太了不起了。
Xilinx似乎在说的是,公司必须购买一台单独的服务器才能拥有他们的许可证! 这需要尽快修复。 地球上几乎每个人都不会浪费资金或资源将许可服务器从虚拟机转移到裸机上? 以上来自于谷歌翻译 以下为原文 This is amazing. What Xilinx seems to be saying is that a company must buy a separate server JUST TO HOST THEIR license! This needs to be fixed ASAP. Almost every person on the planet wouldn't waste the money or resources to move their license server from a VM to bare-metal? |
我刚刚在Mac上的VMWare Fusion下运行的Windows 7上加载了2014.3,我遇到了上述作者提到的关于激活许可的完全相同的问题。
哎呀! 我需要Vivado HLS来工作,因为我正在阅读Zynq书中的那些部分...... 以上来自于谷歌翻译 以下为原文 I just loaded 2014.3 on my Windows 7 running under VMWare Fusion on a Mac and I have the exact same problem mentioned by the above authors regarding activation licensing. Yikes! I need Vivado HLS to work for as I'm reading through those sections in the Zynq book... |
只有小组成员才能发言,加入小组>>
2300 浏览 7 评论
2708 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2192 浏览 9 评论
3274 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2341 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
619浏览 1评论
1674浏览 1评论
174浏览 1评论
640浏览 0评论
1828浏览 0评论
GMT+8, 2024-9-15 07:34 , Processed in 1.573120 second(s), Total 113, Slave 96 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
