电子发烧友论坛|
请您理解有关虚拟机许可证的位置。
我有一个运行Web pack(xml)许可证的Vivado 15.2的Windows 7安装。 我在Virtual Box上安装了Linux,需要使用相同的xml许可证文件 尝试加载(激活许可证..)导致无法将Lcence权限加载到可信存储中 之前的帖子令人困惑,但建议在许可VM安装时出现问题 - 请你澄清这个问题的解决方案 以上来自于谷歌翻译 以下为原文 Please can you calrify the position regarding Virtual Machine licences. I have a Windows 7 installation of Vivado 15.2 running Web pack (xml) licence. I have Linux installation on Virtual Box and need to use same xml licence file Attempts to Load (Acivate Licence..) result in Unable to load Lcence Rights into Trusted Storage Previous posts are confusing but suggest there is a problem licencing VM installs - please can you clarify the solution to this problem |
2个回答
Hi@richard.andrews
您能详细说明生成和安装许可证(.xml)所遵循的步骤吗? 支持具有recommendedOS的VM。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @richard.andrews Can you elaborate on the steps you followed to generate and install the license (.xml)? VMs with recommended OS are supported. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
由于我的Windows安装已获得许可,因此我已经生成了许可证文件,除非我使用新的电子邮件地址创建新帐户,否则不允许生成任何其他文件。
我可以使用“加载许可证”找到.xml文件,但它失败了,如上所述。 以上来自于谷歌翻译 以下为原文 As I have Windows installation already licensed, I have the licence file already generated and I am not permitted to generate any more unless I create a new account with new e-mail address. I can find the .xml file using 'Load License' but it fails as described. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 18:02 , Processed in 0.698441 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2350
