电子发烧友论坛|
我有“无法将许可权限加载到可信存储”错误。
唯一的办法 是通过删除所有相关文件和/或文件夹来删除任何以前的许可证记录。 那么存储许可证的“存储”位置在哪里? 有人可以给我指示我可以完全在哪里 删除旧许可证的所有痕迹并重新开始? 谢谢。 以上来自于谷歌翻译 以下为原文 I have the "cannot load license rights into trusted storage" error. The only way is to delete any previous license record by deleting all related files and/or folders. So where is this "storage" locations where the license are stored? Could someone give me instructions as to where I can completely delete all traces of the old license and start fresh? Thanks. |
3个回答
你好@ andy92806
您是否已生成激活许可证? 如果是,请共享许可文件并输出xlicclientmgr -l“format = xml” 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @andy92806 Did you generate the activation license already? If yes, share the license file and output of xlicclientmgr -l "format=xml" Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
查看此讨论https://forums.xilinx.com/t5/Installation-and-Licensing/Unable-to-load-License-Rights-into-Trusted-Storage/td-p/567531
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check this discussion https://forums.xilinx.com/t5/Installation-and-Licensing/Unable-to-load-License-Rights-into-Trusted-Storage/td-p/567531Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨,
请参阅命令的输出 - xlicclientmgr -l“format = xml” 谢谢。 6 6 COMPOSITE 10035968 11.11.00HostInformation> 1DefaultOneType> SRV175160C047A27ABEB68DC4E55557E66D1B37ECOKnone174AAD04159033649B4F4E158B81C845D2336FC2FD96A8730B04DF932E49E6525EE20F75C9FCB91 6AB575BFA5924A3B7EC8F462F1F023788114F2E56B8CD4DD1B524A43567D74 2015-07-28T23:13:49-07:00 9DE07425DD9732ECD4BCB5A5DBBA2931A09DAFB81 以上来自于谷歌翻译 以下为原文 Hi, Please see the output of the command -- xlicclientmgr -l "format=xml" Thanks. EC FC B9 F023788114F2E56B8CD4DD1B524A43567D74 |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 07:12 , Processed in 0.740695 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4272
