电子发烧友论坛|
所以我昨晚得到了一个新的Hades Canyon NUC,配备了32GB的DRAM和1TB SSD,当我启动并通过HDMI连接显示器时,它没有显示任何内容。
我尝试了在论坛上阅读的技巧,在我插入电源的同时按下电源按钮(这看起来像是糟糕的电源管理固件,但无论如何)它启动了,我能够安装Windows 10.我装了 一个应用程序(Adobe Lightroom)导入一些照片并在一夜之间刻录。 今天早上我在最新的Windows驱动程序更新后重新启动它,它是一个完整的砖块。 当我打开电源时,屏幕上任何东西都不会出现在HDMI端口之外。 键盘和鼠标不会亮起 - USB。 当我使用“电源开启和插入技巧”时,有时电源LED变为蓝色,但大多数情况下只有一个橙色LED亮起。 (我无法在任何地方找到LED代码文档...谢谢!)。 我试过删除安全跳线,删除SSD,删除内存。 即使删除了内存,它也不会启动并发出任何蜂鸣声/闪烁代码。 我也试过电源按钮上的“按下硬”无济于事。 我很困惑 - 它不应该比这更容易,更可靠吗? DG 以上来自于谷歌翻译 以下为原文 So I got a new Hades Canyon NUC last night, kitted it out with 32GB of DRAM and 1TB SSD and it didn't display anything when I booted it up and had the monitor connected via HDMI. I tried the trick I read on the forums of pressing the power button exactly at the same time as I inserted the power (which seems like poor power management firmware, but whatever) and it booted and I was able to install Windows 10. I loaded up one app (Adobe Lightroom) to import some photos and burn it in overnight. This morning I rebooted it after the latest Windows drivers were updated and it is a total brick. When I power it on nothing hits the screen, ever, out of either HDMI port,. The keyboard and mouse do not light up wither - USB. Sometimes the Power LED goes Blue when I use the 'power on and plug in trick' but most of the time just one orange LED is on. (I can't find LED code docs anywhere... thanks!). I have tried removing the security jumper, removing the SSD, removing the memory. Even with the memory removed it doesn't power up and give any beep/blink codes. I also tried the 'press hard' on the power button to no avail. Am quite confused - isn't it supposed to be easier and more reliable than this? dg |
4个回答
看起来你还没有尝试过一件事:
断开CMOS电池连接器并在15分钟后重新连接。 莱昂 编辑 对于电源LED闪烁代码,请参阅第 技术产品规格第63页上的第4页:https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i7HVK_TechProdSpec.pdf 以上来自于谷歌翻译 以下为原文 Looks that one thing you didn't try yet: Disconnect the CMOS battery connector and reconnect is after 15 minutes. Leon Edit For Power LED blinking Codes please refer to para. 4 on page 63 of Technical Product Specification: https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i7HVK_TechProdSpec.pdf |
因此,当我收到您的电子邮件时,我设法让它以某种方式启动。 我不得不在插入电源时按下电源按钮,然后拔下插头并插入HDMI电缆。 从那里我能够加载最新的BIOS。 我现在正在更新所有英特尔设备驱动程序(考虑到您的网络工具使您在许多设备驱动程序更新后重新启动,这有点繁琐。 我不确定它是怎么回事,希望新的BIOS可以稳定... DG 以上来自于谷歌翻译 以下为原文 So as I was receiving your email I managed to get it to somehow boot. I had to hold the powe rbutton down while plugging it in and then unplug and plugin the HDMI cable. From there I was able to load the latest BIOS. Am now updating all of the Intel device drivers (which is a tad onerous considering your web tool makes you reboot after many of the device driver updates. Am not sure what is going on with it, hopefully the new BIOS will stabilize things... dg |
nmmmma 发表于 2018-11-28 07:41 我很高兴您的NUC再次活着。 我只是手动更新驱动程序。 一个接一个。 在最后一个驱动程序更新后,我只重启计算机一次。 祝你好运 莱昂 以上来自于谷歌翻译 以下为原文 I'm glad that your NUC is alive again. I'm updating driver manually only. One after each other. I'm rebooting computer only once, after the last driver is updated. Good luck Leon |
nmmmma 发表于 2018-11-28 07:41 对你起作用吗? 如果是这样,请分享如何处理CMOS电池? 我有同样的问题和权重要求RMA。 谢谢。 以上来自于谷歌翻译 以下为原文 Does it work for you? If so would you please share how to do with CMOS battery? I'm having same problem and weighting to claim RMA. Thanks. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 00:44 , Processed in 1.087214 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4065
