NUC8i7HVK现在通过thunderbolt 3接口支持5K分辨率。
但... 凭借最新的胜利10 OS,NUC8i7HVK(Hades NUC)将在按下电源按钮后从睡眠状态唤醒后自动重启。 似乎雷电3接口的唤醒机制存在兼容性问题。 现在除了禁用睡眠功能我什么都不做,英特尔可以做点什么来解决问题,因为英特尔是霹雳3启动器。 以上来自于谷歌翻译 以下为原文 NUC8i7HVK support 5K resolution via thunderbolt 3 interface now. But... with latest win 10 OS, NUC8i7HVK(Hades NUC) will auto restart after press power button to wake up from sleep. Seems there is compatibility issue for wake up mechanism of thunderbolt 3 interface. Now I can do nothing except to disable sleep feature, can intel do something to solve the issue, since intel is thunderbolt 3 Initiators. |
11个回答
杰弗里,
为了澄清,NUC8i7HVK没有通过官方技术产品规范在单根雷电/直流电缆上列出5K作为支持配置。 https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i7HVK_TechProdSpec.pdf 具体而言,5120x2880支持通过双电缆连接。 您能否提供您在英特尔网站上列出的内容。 以上来自于谷歌翻译 以下为原文 Jeffrey, For clarification the NUC8i7HVK does not list 5K over a single thunderbolt/dp cable as a supported configuration via the official Technical Product Specification. https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i7HVK_TechProdSpec.pdf Specifically the 5120x2880 support is over a dual-cable connection. Can you provide where you have seen this listed on Intel's site. |
hwerewer 发表于 2018-10-18 07:46 嗨Rwashington 我还没有在intel网站上看到它,但真正的事实是NUC8i7HVK现在通过thunderbolt 3接口支持5k分辨率(5120x2880)(通过单个Thunderbolt 3接口流两个DP信号)。 我现在唯一的问题是当从睡眠中唤醒时NUC自动重启(基于我的有限知识,当NUC唤醒时似乎有一些信号丢失,也许NUC需要通过thunderbolt 3接口发送一些特定信号来显示 )。 在YouTube上有关于它的测试结果,这就是我为LG 5K显示器购买NUC8i7HVK的原因。 对于上一代NUC(骷髅峡谷),通过单个霹雳3接口也有关于5K的相关讨论,它不能通过单个霹雳3接口支持5K。 骷髅峡谷,LG Ultrafine 5K显示屏,两个流通过霹雳(2560x2880)解决方案? 以上来自于谷歌翻译 以下为原文 Hi Rwashington I haven't seen it anywhere on intel website, but the real fact is the NUC8i7HVK do support 5k resolution(5120x2880) via thunderbolt 3 interface now(Stream two DP signals via single thunderbolt 3 interface). The only issue I am having now is that the NUC auto restart when wakeup from sleep(based on my limited knowledge, it seems there is some signal missing when NUC wake up, maybe NUC need to send some specific signal to display via thunderbolt 3 interface). There is test result about it on YouTube, that's the reason why I purchased NUC8i7HVK for my LG 5K display. There is also a related discussion about 5K via single thunderbolt 3 interface for the last generation NUC (Skull Canyon), which can't support 5K via single thunderbolt 3 interface. Skull Canyon, LG Ultrafine 5K display, two streams via thunderbolt (2560x2880) workaround? |
btywyrww 发表于 2018-10-18 08:03 杰弗里, 您发布的链接中的主题 并不是说骷髅峡谷或任何NUC上的5K是可能的。 它主要是指关于Apple产品的商业广告。 以上来自于谷歌翻译 以下为原文 Jeffrey, The thread in the link you posted DOES NOT say that 5K is possible on the Skull Canyon or any NUC for that matter. It is referring to commercial about Apple products, mostly. |
麦克风 我并不是要证明骷髅峡谷支持5K分辨率。 相反,我试图通过将2 x DP1.2信号组合成单个Thunderbolt 3接口,让您知道单个Thunderbolt 3接口如何支持5K分辨率。 真正的事实是NUC8i7HVK(Hades NUC)现在通过单个Thunderbolt 3接口支持5k分辨率。 它正在我的桌面上工作!!!!! 奇怪的是,这里的人们试图否认真实的事实(哈迪斯NUC支持5K分辨率,5120 x 2880)。 我试图报告的问题是睡眠后出现唤醒问题,而不是Hades NUC是否支持5K分辨率。 只需获得一个LG 5K显示器并进行测试,您就会明白我在说什么。 事实胜于雄辩。 以上来自于谷歌翻译 以下为原文 Mike I am not trying to proof that the Skull Canyon support 5K resolution. Instead, I am trying to let you know how single thunderbolt 3 interface support 5K resolution by combining 2 x DP1.2 signals into single thunderbolt 3 interface. The real fact is that NUC8i7HVK(Hades NUC) do support 5k resolution via single thunderbolt 3 interface now. It is working on my desktop now!!!!! It is strange that people here try to deny the real fact(Hades NUC support 5K resolution, 5120 x 2880). The issue I am trying to report is that there is wake up issue after sleep, not whether Hades NUC support 5K resolution or not. Just get one LG 5K display and test, and you will understand what I am saying. Facts speak louder than words. |
hwerewer 发表于 2018-10-18 07:46 嗨Rwashington 不幸的是,您链接的数据表说它支持通过2 x DP1.2进行5K显示,这正是LG 5K的工作原理。 两个后C型接口与NUC拥有的两个Thunderbolt 3接口的接口完全相同。 以上来自于谷歌翻译 以下为原文 Hi Rwashington Unfortunately, the data sheet you linked say that it supports 5K display via 2 x DP1.2, this is exactly how LG 5K works. Two rear Type C interfaces are exactly the same interfaces of two thunderbolt 3 interface the hades NUC have. |
btywyrww 发表于 2018-10-18 08:39 更多证明。 在Windows 10中选择了5K分辨率! LG 5K的单雷霆3接口。 以上来自于谷歌翻译 以下为原文 More proofs. 5K resolution selected in Windows 10 ! single thunderbolt 3 interface of LG 5K. |
杰弗里, 虽然很高兴看到面板以预期的分辨率为您工作,但推迟的原因更多地与验证配置的信号完整性有关,而不是简单地说“我们不会支持您”。 因为Alpine Ridge控制器仅允许DP1.2而不是完全验证的DP1.3或更高版本,它在测试实验室而不是单独测试时获得认证结果。 话虽这么说,我相信我们在实验室周围有一个专家组,我们可以尝试在睡眠后复制你重新启动的结果,而不是像预期的那样醒来。 你能否确认一下你在系统上使用的BIOS版本,以及igpu和dgpu的图形驱动程序版本? 以上来自于谷歌翻译 以下为原文 Jeffrey, While it is good to see that the panel is working for you at the expected resolution the reason for the pushback has more to do with signal integrity of a validated configuration rather than simply saying "we won't support you". Because the Alpine Ridge controller only allows for DP1.2 rather than fully validated DP1.3 or higher its a certification result at a test lab rather than individual testing. That being said, I believe we have a panel around the lab here that we can try to replicate your findings of reboot after sleep rather than waking as expected. Can you confirm for me the BIOS version you are using on the system, as well as the graphics driver versions for both the igpu and dgpu? |
hwerewer 发表于 2018-10-18 09:10 嗨Rwashington 很高兴看到你的回复,让我们继续前进来解决问题,我将竭尽所能解决问题。 bios版本是:0049。 igpu的驱动程序版本是:24.20.100.6229 dgpu的驱动程序版本是:24.20.11026.1 我还在这里附上了intel System Support Utility的运行结果。 谢谢。 SSU_Result.txt.zip 32.3 K. 以上来自于谷歌翻译 以下为原文 Hi Rwashington Glad to see your reply, let us move forward to solve the issue, I will do everything I can to get the issue resolved. The bios version is: 0049. driver version for igpu is: 24.20.100.6229 driver version for dgpu is: 24.20.11026.1 I also attached running result of intel System Support Utility here. Thanks.
杰弗里你好, 我想给你一个更新。 我能够从同事那里采购LG 5K Thunderbolt 3显示器进行测试,并且能够像你建议的那样通过单根雷电线以5K @ 60hz的速度运行HVK。 但是,我无法重现您的系统无法从睡眠状态唤醒的具体问题,而是重新启动。 我的设置使用与0049,6229和11026.1相同的驱动程序和BIOS设置。 然而,我正在查看您的某些SSU.txt,并注意到您正在运行一些与VMware相关的任务,请问您使用的是哪种使用模式? 您还连接了TBT3显示器以及大多数时间可能运行的任何其他显示器或外围设备的设备。 我尝试使用三星NVMe驱动器以及基于sata的安装,但两者都无法从睡眠问题重现相同的重启。 以上来自于谷歌翻译 以下为原文 Hello Jeffrey, I wanted to give you an update on this. I was able to source the LG 5K Thunderbolt 3 monitor from a coworker to test with and was able to run the HVK at 5K@60hz over a single thunderbolt cable as you had suggested. However, I was unable to reproduce your specific issue of the system failing to wake from sleep, instead rebooting. My setup is set with the same drivers and bios as you have with 0049, 6229, and 11026.1. I was however looking through some of your SSU.txt and noticed that you are running some VMware related tasks, can I ask what kind of usage model you are using? Also what devices you have connected to both the TBT3 monitor, as well as any other monitors or peripherals you may have running most of the time. I tried with both a Samsung NVMe drive as well as a sata based install and neither were able to reproduce the same reboot from sleep issue. |
hwerewer 发表于 2018-10-18 09:29 Rwashington 感谢您为测试所做的努力。 NUC在家中使用最多,正常家庭使用。 我将卸载不经常使用的VMware。 没有设备连接到LG 5K,但它嵌入了WebCam和麦克风。 我还发现有一个设备缺乏驱动程序支持。 除了两个蓝牙设备,罗技键盘和鼠标外,还没有连接到Hades NUC的外围设备。 - 罗技K760太阳能键盘 - 罗技M557鼠标 我将尝试将Hades NUC连接到HDMI电视以验证睡眠问题,同时您是否可以提供一些捕获跟踪日志的方法来分析重启原因? 我将在下周日回复。 谢谢。 以上来自于谷歌翻译 以下为原文 Rwashington Thanks for the effort made for the test. The NUC is used most at home, normal home usage. I will uninstall VMware, which is not used frequently. There is no device connected to LG 5K, but it has embedded WebCam and Microphone. Also I found there is a device which lack driver support. There is also no peripherals connected to Hades NUC, except two bluetooth devices, Logitech keyboard and mouse. - Logitech K760 Solar Keyboard - Logitech M557 Mouse I will try to connect the Hades NUC to HDMI TV to verify the sleep issue, meanwhile can you provide some methods to capture trace log to analysis the reboot reason? I will respond on Sunday next time. Thanks. |
Rwashington 只是为了更新 今天,我做了一些测试,在以下情况下重复从睡眠问题唤醒后重新启动: 1.卸载VMware,通过thunderbolt 3连接到LG 5K。 2.通过迅雷3断开所有蓝牙设备(关闭蓝牙键盘和鼠标),USB键盘和LG 5K。 3.通过HDMI端口连接到1080P电视。 突然间,我发现即使快速启动被禁用也无法进入BIOS,并且在启动时没有显示Fn提示,即使Fn提示显示复选框也被选中。 我的NUC似乎存在一些硬件问题,我将联系英特尔支持团队进行硬件修复。 之后,我将更新结果。 谢谢。 以上来自于谷歌翻译 以下为原文 Rwashington Just for an update Today, I made some tests, reboot after wakeup from sleep issue repeated in below scenarios: 1. uninstalled VMware, connected to LG 5K via thunderbolt 3. 2. disconnected all bluetooth devices(power off bluetooth keyboard and mouse), USB keyboard and LG 5K via thunderbolt 3. 3. connected to 1080P TV via HDMI port. Suddenly, I found I can not enter into BIOS even fast boot is disabled, and no Fn prompt displayed at booting even Fn prompt display checkbox is checked. It seems there is some hardware issue with my NUC, I will contact intel support team for the hardware fix. After that, I will update the result. Thanks. |
只有小组成员才能发言,加入小组>>
516浏览 0评论
GMT+8, 2024-12-22 19:30 , Processed in 0.923058 second(s), Total 67, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
