电子发烧友论坛|
你好,
我想检查NUC8i7HVK是否支持自定义显示器(我现在没有它,正在制造),其像素定义为5760x1080。 我有一些表格中有关于该屏幕的数字,但我无法将它们与NUC提供的规格完全匹配。 我对像素时钟值特别感兴趣,NUC需要支持的最小值为350 MHz。 我怀疑NUC能够根据其他带宽值或时钟来支持这个要求,但我需要有一些来自英特尔(或本例中的AMD)的官方表确认这一点,所以我可以验证NUC8i7HVK的选择 。 有谁知道我可以在哪里获得这台电脑支持的像素时钟? 提前致谢。 问候, 弗朗索瓦 以上来自于谷歌翻译 以下为原文 Hello, I want to check if the NUC8i7HVK will support a custom display monitor (I don't have it right now, it is being manufactured) that have a pixel definition of 5760x1080. I have a few tables with numbers about that screen but I can't match them exactly with the specs provided from the NUC. I am particularly interested in the pixel clock value, the minimum I need to be supported by the NUC would be 350 MHz. I suspect the NUC is more than able to support this requirement, based on others bandwidth values or clocks, but I need to have some official table from Intel (or AMD in this case) confirming this, so I can validate the choice of a NUC8i7HVK. Does anyone know where I can get the pixel clock supported by this computer ? Thanks in advance. Regards, Francois |
2个回答
嗨fpoepnp,
这不是您问题的直接答案,而是一个侧面问题。 您打算如何连接自定义显示器? DP,USB-C(TB3),HDMI? 如果使用DP,请考虑 DisplayPort具有许多固定速率,数据可以在电缆上传输。 当选择不需要特定物理时钟的带宽量的视频模式时,插入空数据字。 每个物理时钟速度都有自己的名称。 RBR:降低比特率。 1.64 Gbps.HBR1:高比特率1. 2.7 Gbps.HBR2:高比特率2. 5.4 Gbps。 (DP 1.2引入)HBR3:高比特率3:8.1 Gbps。 (DP 1.3引入) 我不确定USB-C 40Gbps(TB3) 以上来自于谷歌翻译 以下为原文 Hi fpoepnp, This is not a direct answer to your question, but a side question. How are you planning on connecting to the custom monitor? DP, USB-C (TB3), HDMI? If using DP, please consider DisplayPort has a number of fixed rates at which data can travel on the cable. When a video mode is selected that doesn't need the amount of bandwidth of a particular physical clock, empty data words are inserted instead. Each of the physical clock speeds has its own name.
I'm not sure about USB-C 40Gbps (TB3) |
嗨MikeLevine。 实际上,它将是DP,根据你提到的数字,这个NUC支持的DP 1.2似乎足以满足我的需求。 我理解这一点的方式是我需要考虑覆盖需求的固定速率,而不是简单的带宽计算。 但无论如何,它似乎也适合这种情况。 谢谢你的评论! 问候 弗朗索瓦 以上来自于谷歌翻译 以下为原文 Hi MikeLevine. Indeed, it will be DP, and according to the numbers you mention, DP 1.2 which is supported by this NUC seems to be sufficient for my needs. The way I understand this is that I need to consider the fixed rate that covers the needs, instead of a simple bandwidth calculation. But anyway, it seems to fit in this case too. Thanks for your comment! Regards Francois |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 01:40 , Processed in 0.707253 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4347
