电子发烧友论坛|
嗨,我已经有了一段时间我的NUC8i7HVK NUC并且从第1天开始就遇到了这个问题,但是刚刚没有像HDMI一样发布它。
我无法将其连接到通过mini-DP支持Freesync的Acer KG251QF 144hz显示器。 当我这样做时,我没有从显示器得到任何信号,只有当我插入HDMI时才能获得一个奇怪的屏幕共享模式。 正如你所看到的,即使我只使用一台显示器,它也会认为插入了两个显示器,迷你DP连接到我可以假设的240p,主屏幕是HDMI。 您还可以看到Monitor 1,它表示不支持Freesync,并且即使它应该同时支持此监视器,也不支持Virtual SUper Resolution。 我有显示器和NUC的最新驱动程序,但无法弄清楚可能是什么问题。 任何帮助非常感谢。 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I've had my NUC8i7HVK NUC for a while and have had this issue since day 1 but have just not posted it as was making do with HDMI. I am unable to connect it to my Acer KG251QF 144hz monitor which supports Freesync via mini-DP. When I do, I get no signal from the monitor and it is only if I plug in the HDMI do I get a wierd screen sharing mode. As you can see, even though I'm only using one monitor, it somehow thinks there is two plugged in and the mini-DP one goes to what I can assume is 240p and the main screen is the HDMI. You can also see that Monitor 1, it states Freesync not supported and Virtual SUper Resolution not supported even when it should support both with this monitor. I've got the latest drivers for the monitor and the NUC but can't figure out what could be the issue. Any help much appreciated. Thanks |
1个回答
你有没有更新NUC BIOS?
下载BIOS更新[HNKBLi70.86A] 文件 以上来自于谷歌翻译 以下为原文 Have you updated the NUC bios? Download BIOS Update [HNKBLi70.86A] Doc |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-17 14:38 , Processed in 0.870698 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8306
