嗨,
我有一个使用LUTx原语设计的exorgate。 一些LUT具有标签,例如xorgate32.vhd文件中的标签“xorgate32_TLUT1_a134not”(附件)。 我已经打包了xorgate32.vhdas用户IP(称为axi_xor_2016)。 该IP安装在AXI总线上以连接Zynq PS。 我试图使用TCL命令“get_cells”逐步读取设计层次结构,直到我到达axi_xorIP。 我期待标签出现在列表中。 我的主要目标是为xorgate的所有放置的LUT获取切片坐标。首先,我想在xorgate的层次结构级别读取所有放置的LUT的列表,然后获取每个LUT的name属性。 请让我知道我该怎么做。 谢谢。 xorgate32.vhd 7 KB 以上来自于谷歌翻译 以下为原文 Hi, I have an exor gate designed using LUTx primitive. Some LUTs have labels for example, the label "xorgate32_TLUT1_a134not" in the xorgate32.vhd file (attached). I have packed the xorgate32.vhd as user IP (called axi_xor_2016). This IP is mounted on AXI bus to connect the Zynq PS. I am trying to use TCL command "get_cells" to read the design hierarchy step by step until I reach the axi_xor IP. I was expecting the labels to appear on the list. My main objective is to get the slice coordinates for all placed LUTs of the xorgate. For this first, I want to read a list of all placed LUTs at the level of the hierarchy of xorgate, and then get the name property for each one. Please let me know how can I do this. Thanks. xorgate32.vhd 7 KB |
7个回答
嗨@amitkulkarnis。
查看DCP,EXORS层次结构不包含任何逻辑。 只有一个32位总线从输入连接到输出。 逻辑可能在前面的步骤中进行了优化。我将查看综合和opt_design(使用-verbose选项)日志以查看优化发生的位置。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @amitkulkarnis. Looking at the DCP, the EXORS hierarchy does not contain any logic. There is only a 32-bit bus that connects from the input to output. The logic likely was optimized in an earlier step. I would take a look at the synthesis and opt_design (with the -verbose option) logs to see where the optimization is occurring. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- View solution in original post |
要获取特定模块中的LUT列表:例如:get_cells -hier -filter {NAME = ~design_1_i / axi_xor_2016_0 / U0 / *&&
REF_NAME = ~LUT *}获取LOC信息:get_property LOC [get_cells XX] -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 To get the LUT list in the specific module: Ex: get_cells -hier -filter {NAME =~ design_1_i/axi_xor_2016_0/U0/* && REF_NAME =~ LUT* } To get the LOC info: get_property LOC [get_cells XX]------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@hongh
我尝试使用Vivado 2018.2采用相同的方法 get_cells -hier -filter {NAME = ~design_1_i / axi_xor_2018_0 / U0 / axi_xor_2018_v1_0_S00_AXI_inst / *} 给出一个列表,其中包含带有标签EXORS的exor门实例化。 然而, get_cells -hier -filter {NAME = ~design_1_i / axi_xor_2018_0 / U0 / axi_xor_2018_v1_0_S00_AXI_inst / *&& REF_NAME = ~LUT *} 返回一个不包含我的exor门实例化的列表。 如果我使用 get_property LOC [get_cells design_1_i / axi_xor_2018_0 / U0 / axi_xor_2018_v1_0_S00_AXI_inst / EXORS] 它返回空列表。 我不确定为什么我的xor IP LUT在层次结构中看不到。 谢谢。 以上来自于谷歌翻译 以下为原文 @hongh I tried the same approach using Vivado 2018.2 get_cells -hier -filter {NAME =~design_1_i/axi_xor_2018_0/U0/axi_xor_2018_v1_0_S00_AXI_inst/*} gives a list that contains my exor gate instantiation with label EXORS. However, get_cells -hier -filter {NAME =~design_1_i/axi_xor_2018_0/U0/axi_xor_2018_v1_0_S00_AXI_inst/* && REF_NAME =~ LUT*} returns a list that does not contain my exor gate instantiation. If I use get_property LOC [get_cells design_1_i/axi_xor_2018_0/U0/axi_xor_2018_v1_0_S00_AXI_inst/EXORS] it returns empty list. I am not sure why my xor IP LUTs could not be seen in the hierarchy. Thanks. |
你能分享一下你的opt.dcp吗?
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Could you share your opt.dcp?------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@hongh
您可以在此处访问opt.dcp文件:https://www.dropbox.com/s/b6qolchja40386s/design_1_wrapper_opt.dcp?dl = 0 谢谢。 以上来自于谷歌翻译 以下为原文 @hongh You can access the opt.dcp file here: https://www.dropbox.com/s/b6qolchja40386s/design_1_wrapper_opt.dcp?dl=0 Thanks. |
嗨@amitkulkarnis。
查看DCP,EXORS层次结构不包含任何逻辑。 只有一个32位总线从输入连接到输出。 逻辑可能在前面的步骤中进行了优化。我将查看综合和opt_design(使用-verbose选项)日志以查看优化发生的位置。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi @amitkulkarnis. Looking at the DCP, the EXORS hierarchy does not contain any logic. There is only a 32-bit bus that connects from the input to output. The logic likely was optimized in an earlier step. I would take a look at the synthesis and opt_design (with the -verbose option) logs to see where the optimization is occurring. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@marcb
非常感谢。 是的,正是在设计优化步骤中吸收了EXOR LUT。 下面是优化报告中的一行:INFO:[选项31-47]吸收到下游逻辑的单元:LUT1单元design_1_i / axi_xor_2018_0 / U0 / axi_xor_2018_v1_0_S00_AXI_inst / EXORS / xorgate32_TLUT1_a134不驱动引脚design_1_i / axi_xor_2018_0 / U0 / axi_xor_2018_0_S00_AXI_inst / axi_rdata [0 ] _1_1 / I0 of design_1_i / axi_xor_2018_0 / U0 / axi_xor_2018_v1_0_S00_AXI_inst / axi_rdata [0] _i_1。 谢谢! 以上来自于谷歌翻译 以下为原文 @marcb Thanks so much. Yes, it was in the design optimization step that absorbed the EXOR LUTs. Below is one of the lines in the optimization report: INFO: [Opt 31-47] Cell absorbed into downstream logic: LUT1 cell design_1_i/axi_xor_2018_0/U0/axi_xor_2018_v1_0_S00_AXI_inst/EXORS/xorgate32_TLUT1_a134not driving pin design_1_i/axi_xor_2018_0/U0/axi_xor_2018_v1_0_S00_AXI_inst/axi_rdata[0]_i_1/I0 of design_1_i/axi_xor_2018_0/U0/axi_xor_2018_v1_0_S00_AXI_inst/axi_rdata[0]_i_1. Thank you! |
只有小组成员才能发言,加入小组>>
2338 浏览 7 评论
2758 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2235 浏览 9 评论
3308 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2384 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
696浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
492浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
277浏览 1评论
703浏览 0评论
1896浏览 0评论
GMT+8, 2024-10-19 23:37 , Processed in 1.504586 second(s), Total 88, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
