电子发烧友论坛|
嘿大家,
我使用6470附加到STM32F0-Discovery,基本上工作正常。唯一的事情是,当加速和减速时,步进器在整个地方都在摇晃,甚至在一定时间内失步。在查看dspin_getStatus()响应时,我看到SCK_MOD位被引发,表明器件处于步进时钟模式,尽管我在init例程中设置了1/128微步进模式。我让电机以一定的速度运行并且每2秒改变一次方向,就像测试序列一样。我使用dspin_run()命令。 为什么我不能退出step_clock模式?使用移动或运行命令时,这不应该自动完成吗? 我之前使用过另一台L6470,我没有遇到这些问题。 任何评论都非常感谢。 斯特凡 #dspin#l6470 以上来自于谷歌翻译 以下为原文 Hey everyone, I am using a 6470 attached to the STM32F0-Discovery which basically works fine. THe only thing is, that when accelerating and decelerating the stepper is shaking all over the place, even losing steps during a certain period. When looking at the dspin_getStatus() response I see SCK_MOD bit raised, indicating that the device is in step-clock mode though I have set 1/128 microstepping mode in my init routine. I let the motor run at a certain speed and change direction every 2 seconds, just as a test sequence. I use dspin_run() command for this. Why can't I get out of step_clock mode? Shouldn't this be done automatically when using a move or run command? I used another L6470 earlier, where I did not have these issues. Any comment is highly appreciated. Stefan #dspin #l6470 |
1个回答
哦,嘿,我想我明白了。
重新检查所有引脚连接到我板上的焊盘后,我发现相位没有正确焊接。所以我重新焊接了所有四个线圈引脚,看,一切都像魅力一样。 很明显,当只有一个线圈在电流下时,行为等于小孩的行为... ;-)这向我解释,为什么大多数时间摆动方向并且移动得非常慢并没有真正起作用。 不过,有一件事,getStatus在移动过程中给了我0x9E50,这意味着,L6470在步进时钟模式下工作,对吗?可能是SPI实现sowmwhere的一些问题? 希望这会有所帮助,万一有人经历同样的wanky行为。 干杯 斯特凡 以上来自于谷歌翻译 以下为原文 Oh hey, I think I got it. After rechecking all pin connections to the solder pads on my board I found that a phase wasn't soldered properly. So I resoldered all four coil pins and see, everything works like a charm. It's obvious that when only having one coil under current, behaviour is equal to that of a little child... ;-) That explained to me, why most of the time toggeling direction and moving very slowly didn't really work. Still, one thing though, getStatus gives me 0x9E50 during movement, which means, L6470 works in step clock mode, right? Maybe some issue with SPI implementation sowmwhere? Hope this helps, in case someone experiences the same wanky behaviour. Cheers Stefan |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 20:38 , Processed in 0.736806 second(s), Total 70, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
408
