电子发烧友论坛|
嗨,
我正在尝试实现一个逻辑,以便输出信号相对于输入连续移位。 具体来说,我有一个20MHz的矩形脉冲作为输入(clk_in),我想以连续的方式移动它。 据我所知(并尝试过),DCM可变相移功能允许我执行移位直到达到极限(256 phase_shift_steps),然后它才能返回。 因此,我试图以乒乓方式使用两个DCM,以便获得输入时钟信号的连续正向移位,但我仍然在与缓冲区问题相关的“MAP”级别的ISE中出现错误。 有没有人试过以这种方式或不同的方式实现这样的逻辑? 任何建议真的很感激! 提前致谢。 最好, 米莫 附: 我正在使用SP601 Spartan6板和ISE版本14.2。 p.p.s. 如有必要,我可以发布我写的VHDL代码。 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to implement a logic in order to have an output signal that continuously shifts with respect to the input. Specifically I have a 20MHz rectangular pulses as input (clk_in) and I would like to shift it in a continuous fashion. As I understood (and tried) the DCM variable phase shift function allows me to perform the shift until it reaches a limit (256 phase_shift_steps), and then it can only go back. Therefore I'm trying to use two DCMs in a ping-pong fashion in order to get a continuous forward shift of my input clock signal, but I continue getting errors in ISE at "MAP" level related to buffer issues. Has anyone tried before to implement such a logic, either in this way or a different one? Any suggestion is really appreciated! Thanks in advance. Best, Mimmo p.s. I'm using the SP601 Spartan6 board and the ISE version14.2. p.p.s. I can post the VHDL code I wrote if necessary. |
2个回答
该论坛旨在讨论实施工具问题。
设计实施问题的更好的论坛是通用技术讨论论坛。 以上来自于谷歌翻译 以下为原文 This forum is intended for discussion of Implementation Tool issues. A better forum for you design implementation question would be the General Technical Discussion forum. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 08:58 , Processed in 0.717792 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2811
