电子发烧友论坛|
您好,我正在查看描述PNA系列各种选项的5990-7745EN.pdf文档。
在页14,在选项87的说明中:不适用于PNA选项200,210,400和410.当配置2端口PNA或2端口PNA-X与选项200或219时,外部信号发生器 和组合器是必需的。 但是,它没有提到选项217.我认为选项217和219之间的主要区别在于219有额外的偏差T恤。 只是想确认选项217还需要外部信号发生器和选件87的组合器才能工作。 此外,对于外部组合器,该部分是否有一些特定要求? 是德科技根据您自己的内部测试有任何建议吗? 我的公司正在寻找PNA 43.5GHz型号。 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, I'm looking through the 5990-7745EN.pdf document describing the various options for the PNA family. On page 14, in the description of Option 87: Not available with PNA Options 200, 210, 400 and 410. When configured with a 2-port PNA or 2-port PNA-X with either Option 200 or 219, an external signal generator and a combiner are required. However, it doesn't mention Option 217. I thought the main difference between options 217 and 219 was that 219 had the additional bias tees. Just wanted to confirm that option 217 also requires an external signal generator and a combiner for Option 87 to work. Also, for the external combiner, is there some specific requirements for that part? Does Keysight have any recommendations based on your own internal testing? My company is looking at PNA 43.5GHz models. Thanks, rok |
4个回答
我认为答案取决于你想到的模特家庭。
你在想PNA-X还是PNA? *对于2端口PNA-X,例如N5244A:*选项200 =基本2端口选项217 = Src& Rcvr Attens Option 219 = Src / Rcvr Atten& 偏置Ts选项224 =第二个Src w / Combiner& 开关*用于2端口PNA,例如N5224A:*选项200 =基本2端口选项217 =可配置TS + Attens选项219 =配置TS + Attens +偏置T恤所以除非您订购224,我相信答案是, 是的,你需要它。 以上来自于谷歌翻译 以下为原文 I think the answer depends upon the model family you have in mind. Are you thinking of a PNA-X or PNA? *For 2-Port PNA-X, such as the N5244A:* Option 200 = Base 2-Port Option 217 = Src & Rcvr Attens Option 219 = Src/Rcvr Atten & Bias Ts Option 224 = 2nd Src w/Combiner & Switches *For 2-Port PNA, such as the N5224A:* Option 200 = Base 2-Port Option 217 = Configurable TS + Attens Option 219 = Config TS+Attens+Bias Tees So unless you order 224, I believe the answer is, yes you need it. |
胡bbs2 发表于 2018-10-11 17:04 你好,谢谢你的回复。 我的公司正在研究PNA,因为我们已经拥有一堆PNA-X。 这就是为什么我有关于外部组合器的后续问题,因为PNA系列没有内部组合器选项。 只是想确保对组合器没有特殊要求,以便能够正确校准。 (即像校准混频器需要互为混频器组延迟测量等)谢谢,rok 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the reply. My company is looking at PNAs, since we already have a bunch of PNA-X's already. That's why I had the follow-up question regarding the external combiner, since the PNA family doesn't have an internal combiner option. Just want to make sure there are no special requirements for the combiner in order to be able to calibrate for it correctly. (i.e. like a calibration mixer needing to be reciprocal for mixer group delay measurements, etc) Thanks, rok |
蓝色冰汐 发表于 2018-10-11 17:19 为了使IMD校准与外部组合器一起正常工作,您还需要在外部组合器之后提供外部耦合器/电桥,并将其耦合臂路由到参考R1输入。 我们的IMD校准假设输入F1和F2信号都可以用R1(或R3取决于IMD通道的输入端口设置)进行测量。 如果您有一个4端口PNA(带有可配置的测试装置选项),您可以使用其中一个未使用的测量耦合器(如端口3或4)作为外部组合器,另一个作为外部耦合器。 以上来自于谷歌翻译 以下为原文 in order for the IMD calibration to work properly with an external combiner, you need to also provide an external coupler/bridge after the external combiner and route the coupled arm of that to the Reference R1 input. Our IMD calibration assumes that both the input F1 and F2 signals can be measured with R1 (or R3 depending on the IMD channel's input port setting). if you have a 4-port PNA (with the configurable testset option), you can use one of the unused measurement couplers (like port 3 or 4) as the external combiner and the other one as the external coupler. |
要轻松了解Dara的含义,您可以查看以下网页:http://na.support.keysight.com/pna/help/latest/Applications/Swept_IMD_Configure_External_Source_and_Combiner.htm具有2端口PNA的框图
如果您的PNA只有一个信号源,则使用外部组合器和信号源进行IMD测量。 如果您的PNA是具有两个源的4端口,则可以使用端口3中的第二个源而不是外部信号源。 以上来自于谷歌翻译 以下为原文 To easily understand what Dara means, you can take a look at the web page below: http://na.support.keysight.com/pna/help/latest/Applications/Swept_IMD_Configure_External_Source_and_Combiner.htm has the block diagram for 2-port PNA IMD measurement with external combiner and signal source, if your PNA only has one source. If your PNA is 4-port with two sources, you can use the second source from port 3 instead of the external signal source. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:33 , Processed in 2.133715 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1853
