我们目前有_2端口PNA(E8363C)_和_4端口PNA-X(N5245A)_,即将获得_4端口ENA(E5071C)_。
你知道PNA的相同* SCPI命令*是否可以用来控制ENA吗? 我们正在尝试重用我们为PNA所做的一些labview代码。 如果没有,是否有*交叉引用*显示哪些命令不同/相同? 我意识到设备的功能各不相同,因此某些cmd不适用。 以上来自于谷歌翻译 以下为原文 We currently have a _2 Port PNA (E8363C)_ and a _4 Port PNA-X (N5245A)_ and are about to get a _4 Port ENA (E5071C)_. Do you know if the same *SCPI commands* for the PNA can be used to control the ENA? We are trying to reuse some LabVIEW code we did for the PNA. If not, is there a *cross reference* showing which commands are different/same? I realize that the capabilities of the equipment vary and some cmds are not applicable as a result. |
2个回答
如果您正在购买新的ENA,您可能会认为E5080A是最新的ENA,并且在SCPI和保存/召回中都与PNA兼容。
以上来自于谷歌翻译 以下为原文 If you are acquiring a new ENA, you might consider the E5080A as it is the newest ENA and is compatible with PNA in both SCPI and in save/recall. |
我们需要频率> 9GHz,我认为这是E5080A的极限。 我假设你的回答我们不应该期望SCPI命令对于E5071C和PNA系列是相同的。 如果某种类型的交叉引用显示哪些命令相似/不同,那将非常有用。 以上来自于谷歌翻译 以下为原文 We need freq > 9GHz which I believe is the limit for the E5080A. I assume by your response that we should not expect SCPI commands to be the same for the E5071C and the PNA family. It would be very helpful if there was some type of cross reference that shows which commands were similar/different. |
只有小组成员才能发言,加入小组>>
1091 浏览 0 评论
2311 浏览 1 评论
2100 浏览 1 评论
1974 浏览 5 评论
2844 浏览 3 评论
855浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
625浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
724浏览 0评论
1413浏览 0评论
1091浏览 0评论
GMT+8, 2024-10-6 10:05 , Processed in 1.218243 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
