电子发烧友论坛|
您好,我正在使用带有内部两个源,组合器的双端口N5242A PNA-X,带选项-087(IMD应用程序)。
我一直在尝试使用IMD应用来测量IP2并在扫描功率干扰信号的情况下获得灵敏度。 例如,假设我在2.45 GHz处有所需的音调,干扰音调为5.5 GHz。 我希望在固定引脚= -30 dBm时保持2.45 GHz,同时将5.5 GHz干扰功率从-20 dBm扫描到+10 dBm。 与此同时,我将测量IIP2Hi,IIP2Lo,2.45 GHz的ToneGainLo和5.5 GHz的ToneGainHi。 我遇到的问题是,为了达到我想要的干扰功率扫描范围,我需要使用Source 1作为我的干扰源(因为合成器丢失使得Source 2无法达到我想要的最大干扰功率)。 在IMD应用程序设置中我发现f1在IMD应用程序中,有没有办法让Src 1(具有更高可用端口功率的那个)成为我更高的频率音调而Src 2是我的低频率音调? 我希望能够执行此测试,而无需重新配置测试装置以包含外部放大器。 谢谢 以上来自于谷歌翻译 以下为原文 Hello, I'm using a two port N5242A PNA-X with the internal two sources, combiner, with option -087 (the IMD application). I've been trying to use the IMD app to measure IP2 and gain desense in the presence of a swept power jamming signal. For example, let's say I have a desired tone at 2.45 GHz and a jamming tone is at 5.5 GHz. I want to hold 2.45 GHz at fixed Pin=-30 dBm while sweeping the 5.5 GHz jammer power from -20 dBm through +10 dBm. At the same time I would measure IIP2Hi, IIP2Lo, the ToneGainLo at 2.45 GHz, and the ToneGainHi at 5.5 GHz. The problem I'm having is that, in order to achieve my desired jammer power sweep range, I need to use Source 1 as my jammer source (because the combiner loss makes Source 2 not able to reach my desired max jammer power). In the IMD app setup I find that f1 I'd like to be able to perform this test without needing to reconfigure the test set to include an external amplifier. Thanks |
2个回答
你可以反转PNA背面的环路,将光源3发送到主臂,将源2发送到耦合臂,然后激光器3将具有高频率和高功率。
(不是 - 完全 - 你要求的,但也许它适合你)。 以上来自于谷歌翻译 以下为原文 you could reverse the loops on the back of the PNA to send source 3 to the main arm and source 2 to the coupled arm, then the soruce 3 will have high frequency and high power. (Not -exactly- what you asked for, but maybe it works for you). |
脑洞大赛9 发表于 2019-1-30 11:08 这是路径配置的片段 以上来自于谷歌翻译 以下为原文 here's a snippet from the path configuration 附件
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:55 , Processed in 0.848151 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1853
