电子发烧友论坛|
你好PNA-X用户,我在PNA-X上运行A.09.42.16并尝试通过SCPI配置功率调整模式。
GUI为我提供了4个选项:1设置输入功率2设置输入功率,接收器调平3设置输入功率,输出4等音调设置输出功率,接收器调平帮助文件文件:sense:imd:tpower:equalize:state sense :imd:tpower:设置我认为后一个命令,将允许我设置状态1和4.但是,如果我想配置情况2(在输入端设置功率,但使用接收器调平),是一个无证的IMD 我可以设置的命令。 或者我是否必须开始编程接收器调平系统(在这种情况下,我怀疑我将必须管理我配置调平的源 - 而不是让固件团队进行艰苦的工作!)如果有人能够阐明 配置IMD测量这方面的最佳方法,我将非常感激。 谢谢安迪 以上来自于谷歌翻译 以下为原文 Hello PNA-X users, I am running A.09.42.16 on a PNA-X and trying to configure the power leveling mode via SCPI. The GUI provides me with 4 options: 1 Set input power 2 Set input power, receiver leveling 3 Set input power, equal tones at output 4 Set output power, receiver leveling The help file documents: sense:imd:tpower:equalize:state sense:imd:tpower:set I think the latter command, will allow me to set states 1 and 4. However, if I want to configure for case 2 (set power at the input, but use receiver leveling), is the an undocumented IMD command that I can set. Or do I have to start programming the receiver leveling system (in which case I suspect I will have to manage which sources I configure the leveling for - rather than letting the firmware team do the hard work!) If anyone can shed some light on the best way to config this aspect of an IMD measurement, I would be very grateful. Thanks Andy |
1个回答
好的,一些实验表明我可以用这两个SCPI命令的正确组合来覆盖案例2-4。
我的问题是如何回到案例1? TSET INPUT命令似乎将你设置为案例2/3 - 我似乎无法回到案例1 .... :(谢谢你和 以上来自于谷歌翻译 以下为原文 Okay, a little experimentation suggests that I can cover cases 2-4 with the correct combination of these two SCPI commands. The question I have is how do I get back to case 1? The TSET INPUT command seems to set you to case 2/3 - I cannot seem to get back to case 1.... :( Thanks andy |
只有小组成员才能发言,加入小组>>
315 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2659 浏览 1 评论
2480 浏览 5 评论
1872浏览 0评论
438浏览 0评论
315浏览 0评论
/9
GMT+8, 2025-12-17 19:19 , Processed in 0.623503 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1699
