电子发烧友论坛|
具体地说,我试图颠倒一个UART的输出。我试着在组件的输出中加一个反相器,但是合成器不允许。一般来说,似乎组件引脚只能连接到设备引脚。这似乎是一个很大的限制,所以我想知道我是否错过了一些东西。
以上来自于百度翻译 以下为原文 Specifically, I'm trying to invert the output of a UART. I tried just adding an inverter to the output of the component but the synthesizer won't allow that. In general, it seems like component pins can only be connected to device pins. This seems like a major limitation so I'm wondering if I'm missing something here. |
5个回答
我也愿意交换的TX和RX引脚上的逻辑侧由于布局错误。我曾在psoc5但psoc6似乎不允许这样做没问题。
以上来自于百度翻译 以下为原文 I also would like to swap TX and RX pins on the logic side due to a layout mistake. I had no problem doing this in PSOC5 but PSOC6 doesn't seem to allow this. |
如果您使用UART的UDB实现,这将是可能的。当使用SCB(固定函数块)时,您可以使用SMARTI/O块进行工作。 以上来自于百度翻译 以下为原文 That will be possible if you use an UDB implementation of the UART. When using the SCB (fixed function blocks), you might be able to make it work using the SmartI/O block. |
但是SMARTI/O块只能在P8和P9上使用。如果使用其他端口,则无法工作。 以上来自于百度翻译 以下为原文 But the SmartI/O block is only available on P8 and P9. If you are using other ports, it will not work. |
如何创建UDB UART? 以上来自于百度翻译 以下为原文 How do I create a UDB uart? |
您可以参考PSoC 4/5 UART UDB实现。所有的PSoC都具有相同的UDB体系结构,所以只要你有足够的硬件资源,它们就应该是从一个PSoC到另一个的便携式,只有一些变化。 也许社区里的人已经完成了这项工作。赛普拉斯还计划提供这样的组件,但不是很快。事实上,我们推荐使用SCB作为UART,因为PSoC 6中有很多可用的。但是我知道你的手已经绑好了,因为你已经完成了你的硬件。 以上来自于百度翻译 以下为原文 You could refer to the PSoC 4/5 UART UDB implementation. All the PSoCs have the same UDB architecture, so as long you have enough hardware resources, they should be portable from one PSoC to other, with a few changes. Perhaps someone here in the community already did this work. Cypress also has plans to provide such component as well, but not any time soon. We actually recommend to use SCB for UART, since there are so many available in PSoC 6. But I understand your hands are tied, since you already finalized your hardware. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 11:06 , Processed in 0.823714 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2593
