您好,是否可以直接使用来自FX2LP固件的端点向主机FIFO写入数据而不需要主机?如果是,请发布一些示例代码。
或者,我们有没有一种方法可以在没有主机和USB接口的情况下从8051接口写入FIFO?谢谢和问候,Paramesh 以上来自于百度翻译 以下为原文 Hello, Is it possible to write data to Slave fifo using Endpoints from firmware of fx2lp directly without Host? If so please do post some sample code. Or, is there anway through which we can write from 8051 interface to FIFO without host and USB interface? Thanks and regards, Paramesh |
6个回答
您将能够从8051.HTTP://wwwyCysP.com/手动模式向从属FIFO写入数据。Re= 45 850详细解释,并附带了示例代码。当做,
阿南德 以上来自于百度翻译 以下为原文 You'll be able to write data to slave FIFO in manual mode from the 8051. http://www.cypress.com/?rID=45850 explains it in detail and has sample code along with it. Regards, Anand |
你好,
你是说你想要一个不从主机获得数据的外端点。您只需在端点上写入数据,并将其武装到从FIFO域,以便主机可以读取它? 正如Nikhil所要求的,请分享你的申请。 -加里马 以上来自于百度翻译 以下为原文 Hi, Are you saying you want an OUT endpoint, which does not get data from host. You simply write data on the endpoint and arm it to the Slave FIFO domain, so that master can read it? As Nikhil asked, please share your application. -Garima |
嗨,正如Garima所说,如果你想从FX2LP数据源到奴隶FIFO,你可以这样做如下。保持端点(在这种情况下的EP2)作为无效端点,但在缓冲、方向和自动/手动模式方面配置正确。在这个例子中,我选择了EP2是一个外端点,四缓冲,每个字节512个,手动模式。EP2CFG=0x7f;EP2CFOFFG=0x00;FiPosit=0x80;SimcCdTe= 0x02;SycCdEnter;EP2FIFOBUF(0)=0xAA;SycCdEnter;EP2BCH=0x02;SYNCDELAY;//EP2BCL=0x00;SYNCDELAY;/EP2BCH=0x02;SYNCDELAY;/EP2BCL=0x00;SimcDelp;EP2BCH=0x02;SimcDelp;EP2BCL=0x0;(0;同步延迟;EP2BCH= 0x02;同步延迟;EP2BCL=0x00;同步延迟;FippET= 0x00;问候,Gayathri
以上来自于百度翻译 以下为原文 Hi, As Garima said, if you want to source the data from FX2LP to the Slave FIFO, you can do so as below. Keep the endpoint (EP2 OUT in this case) as invalid endpoint, but configured properly with respect to buffering, direction and Auto/ Manual mode. In this example, I have chosen EP2 to be an OUT endpoint, quad buffered, of 512 bytes each, manual mode. (EP2CFG = 0xA0; EP2CFG &= 0x7F; EP2FIFOCFG = 0x00; ) FIFORESET = 0x80; SYNCDELAY; FIFORESET = 0x02; SYNCDELAY; EP2FIFOBUF[0] = 0xAA; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; // EP2BCL = 0x00; SYNCDELAY; // EP2BCH = 0x02; SYNCDELAY; // EP2BCL = 0x00; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; EP2BCL = 0x00; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; EP2BCL = 0x00; SYNCDELAY; FIFORESET = 0x00; Regards, Gayathri |
抱歉格式化。FiPosit=0x80;FiPosit=0x02;PycPoTe= 0xAa;EP2FIFOBU= 0xAa;SycCdEnter;EP2BCH= 0x02;SycCdEnter;EP2BCL=0x00;SycCdEnter;EP2BCH=0x02;SycCdEnter;EP2BCL=0x00;SycCdEnter;EP2BCH=0x02;SycCdEnter;EP2BCL=0x00;SimcDelp;EP2BCH=0x02;SimcDelp;EP2BCL=0x00;SYNCDELAY;FippET= 0x00;
以上来自于百度翻译 以下为原文 Sorry about the formatting. FIFORESET = 0x80; SYNCDELAY; FIFORESET = 0x02; SYNCDELAY; EP2FIFOBUF[0] = 0xAA; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; EP2BCL = 0x00; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; EP2BCL = 0x00; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; EP2BCL = 0x00; SYNCDELAY; EP2BCH = 0x02; SYNCDELAY; EP2BCL = 0x00; SYNCDELAY; FIFORESET = 0x00; |
我不知道我不能把它做成一个好的格式。:(
以上来自于百度翻译 以下为原文 I do not know I am not able to make it in a good format. :( |
只有小组成员才能发言,加入小组>>
726个成员聚集在这个小组
加入小组1938 浏览 1 评论
1685 浏览 1 评论
3448 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1606 浏览 6 评论
1404 浏览 1 评论
GMT+8, 2024-6-26 10:47 , Processed in 0.847153 second(s), Total 88, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
