先贴报错信息,如下: LD u-boot OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin SYM u-boot.sym DTC arch/arm/dts/rk3036-sdk.dtb DTC arch/arm/dts/rk3188-radxarock.dtb DTC arch/arm/dts/rk3288-miqi.dtb DTC arch/arm/dts/rk3288-phycore-rdk.dtb DTC arch/arm/dts/rk3288-popmetal.dtb DTC arch/arm/dts/rk3288-rock2-square.dtb start=$(/home/saflam/rk3399/rk3399-android-10/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(/home/saflam/rk3399/rk3399-android-10/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end DTC arch/arm/dts/rk3288-tinker.dtb Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319:arch/arm/dts/rk3036-sdk.dtb] 错误 1 make[2]: *** 正在等待未完成的任务.... Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319:arch/arm/dts/rk3188-radxarock.dtb] 错误 1 make[1]: *** [dts/Makefile:101:arch-dtbs] 错误 2 make: *** [Makefile:883:dts/dt.dtb] 错误 2 背景 我的开发板是friendly的nanoPC-T4,rk3399芯片,编译Android10源码因时间太长就睡觉去了,睡醒看编译成功了但是缺少各种img文件,然后就单编u-boot,kernel,编u-boot的时候就报上面的Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error等错误(下面是报错文件摘要),思路被报错信息给带节奏了,最后的#include前面多了个"",一直从编译流程文件里一个一个的捋,绕在去除""的思路里根本无法自拔~>_<~ 排查了四天都没搞清楚,在国内也查不到相关的解决方法,也有人讨论,但是太冷清了也没有回复,真的已经搞懵杯了,番强到google上搜,从搜索的title上也没有找到与这个问题相关的; &usb_host { vbus-supply = <&vcc5v0_host>; status = "okay"; }; &usb_otg { vbus-supply = <&vcc5v0_otg>; status = "okay"; }; &pinctrl { usb_otg { otg_vbus_drv: host-vbus-drv { rockchip,pins = <0 26 RK_FUNC_GPIO &pcfg_pull_none>; }; }; usb_host { host_vbus_drv: host-vbus-drv { rockchip,pins = <2 23 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; #include "rk3036-sdk-u-boot.dtsi" 解决方案 1. vi u-boot/Makefile 添加 KBUILD_CFLAGS += $(call cc-disable-warning, address-of-packed-member) 位置的话理论上讲只要是没有if判断影响执行这句语句的位置都可以; 2. vi u-boot/arch/arm/dts/Makefile CONFIG_ARCH_ROCKCHIP内把报错的dtb删掉;一般就是rk3036-sdk.dtb、rk3188-radxarock.dtb、rk3368-lion.dtb、rk3368-sheep.dtb、rk3368-geekbox.dtb、rk3368-px5-evb.dtb,我记得还有1~2个报错的dtb文件,请根据错误自行删除; 3. vi u-boot/scripts/dtc/dtc-lexer.l 搜索yylloc 把-YYLTYPE yylloc 整行删掉; 4.vi u-boot/scripts/dtc/dtc-lexer.lex.c_shipped 搜索yylloc 把-YYLTYPE yylloc 整行删掉; 5.重新编译,齐活
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1133 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1367 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7082 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2170 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2715 浏览 0 评论
/9
GMT+8, 2025-12-14 22:47 , Processed in 0.739122 second(s), Total 70, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3140
