电子发烧友论坛|
1.引脚定义:
GND接地,VCC供电,X1、X2、X3各自对应一对红外探头 2.实验原理: 红外传感器巡线的基本原理是利用物体的反射性质,当红外线发射到黑色上时会被黑线吸收掉,当红外线发射到不同的颜色的材料上会有不同反射到红外的接手管上,已产生不同大小的光电流,从而影响三路引脚输入电平高低。 3.注意:
#ifndef __REMOTE_H #define __REMOTE_H #define left GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_3) #define mid GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_2) #define right GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0) void remote_init(void); void run_left(void); void run_right(void); void run_forth(void); void run_back(void); void run_stop(void); #endif remote.c #include "remote.h" #include "sys.h" void remote_init() { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //开启IO口对应的时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2|GPIO_Pin_3; //PA2 PA3 GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0; //PB0 GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB,&GPIO_InitStructure); } void run_forth() { TIM_SetCompare1(TIM4,780); TIM_SetCompare2(TIM4,899); TIM_SetCompare3(TIM4,782); TIM_SetCompare4(TIM4,899); } void run_left() { TIM_SetCompare1(TIM4,860); TIM_SetCompare2(TIM4,899); TIM_SetCompare3(TIM4,760); TIM_SetCompare4(TIM4,899); } void run_right() { TIM_SetCompare1(TIM4,760); TIM_SetCompare2(TIM4,899); TIM_SetCompare3(TIM4,860); TIM_SetCompare4(TIM4,899); } void run_back() { TIM_SetCompare1(TIM4,899); TIM_SetCompare2(TIM4,800); TIM_SetCompare3(TIM4,899); TIM_SetCompare4(TIM4,800); } void run_stop() { TIM_SetCompare1(TIM4,899); TIM_SetCompare2(TIM4,899); TIM_SetCompare3(TIM4,899); TIM_SetCompare4(TIM4,899); } main.c #include "sys.h" #include "delay.h" //#include "usart.h" #include "led.h" #include "oled.h" #include "motor.h" #include "timer.h" #include "remote.h" //#include "tick_ulsonic.h" //#include "ultrasonic.h" /*********************************************************************************************** 本来是一个三路巡线模块,但因为模块质量问题,中间识别能力较差,故只使用左右两路,逻辑上也可以实现。 ****************************************************************************************************************/ void pointleft(void); //OLED方向指示 void pointright(void); void pointforth(void); void pointback(void); int main(void) { u8 i=0; u8 val1; u8 val2; SystemInit(); delay_init(); //延时函数初始化 nms<=1864 RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);// 或使用JTAG_Set(0X01); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); LED_Init(); // uart_init(115200); LED_Init(); //初始化与LED连接的硬件接口 OLED_Init(); pwm_init(899,0); // Tim3_Config(); // ulsonic0_config(); // ECHO PA2 TRIG PA3 // ulsonic1_config(); // ECHO PA13 TRIG PA14 remote_init(); delay_ms(1800); delay_ms(1800); delay_ms(1800); run_forth(); while(1) //基于实际操作环境,在纸张内返回引脚口读取0,纸张外读取1。 { val1=left; val2=right; switch(val1+val2) { case 2 : run_back();pointback(); //两边跑离纸面 break; case 1 : if(val1==1) //一边跑离纸面 {run_right();pointright(); } else{ run_left();pointleft(); } break; case 0 : run_forth();pointforth(); //在纸面内 break; default: break; } OLED_ShowNumber(20,20,val1,1,14); OLED_ShowNumber(60,20,val2,1,14); OLED_Refresh_Gram(); i++; if(i==10) { LED=!LED; i=0; } delay_ms(50); } } void pointright() { OLED_Clear(); OLED_ShowString(40,10,"O"); OLED_ShowString(60,20,"O"); OLED_ShowString(80,30,"O"); OLED_ShowString(60,40,"O"); OLED_ShowString(40,50,"O"); OLED_Refresh_Gram(); } void pointleft() { OLED_Clear(); OLED_ShowString(80,10,"O"); OLED_ShowString(60,20,"O"); OLED_ShowString(40,30,"O"); OLED_ShowString(60,40,"O"); OLED_ShowString(80,50,"O"); OLED_Refresh_Gram(); } void pointforth() { OLED_Clear(); OLED_ShowString(60,10,"OO"); OLED_ShowString(50,20,"O O"); OLED_ShowString(40,30,"O O"); OLED_Refresh_Gram(); } void pointback() { OLED_Clear(); OLED_ShowString(60,50,"OO"); OLED_ShowString(50,40,"O O"); OLED_ShowString(40,30,"O O"); OLED_Refresh_Gram(); } 该次功能实现中,三路引脚都能正常运行,但逻辑判断中只用到了左右两路,因为个人试验没有高精度要求,小车在该环境下已经能非常流畅准确的判断、运行。若使用三路引脚判断,可以实现急转弯等更高级的功能,这里不详细说明。 注:在调试中一直遇到读IO口Byte是,1和0显示不准确和不灵敏等问题,在经历了很长一段时间的不断尝试和思考后,最后从最简单的IO配置开始修改,把下拉输入改成了浮空输入模式,整个问题迎刃而解。 |
只有小组成员才能发言,加入小组>>
1599 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4738 浏览 0 评论
4229 浏览 9 评论
3822 浏览 16 评论
4398 浏览 1 评论
4211浏览 3评论
2380浏览 0评论
3394浏览 0评论
1158浏览 0评论
2843浏览 0评论
/9
GMT+8, 2025-12-2 06:41 , Processed in 0.558096 second(s), Total 44, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1117
