电子发烧友论坛|
你好
我想购买和使用PCI 32位启动器/目标IP核。我的FPGA是XC3S200AN Spartan3 / AN。我想知道在这种类型的FPGA上有这个IP核功能。这个问题的答案对我来说非常重要。请帮助 。 以上来自于谷歌翻译 以下为原文 Hi I want to purchase and use PCI 32bit Initiator/Target IP Core.My FPGA is XC3S200AN Spartan3/AN .I want to know that does this IP Core function on this type of FPGA.The answer to this question is very very important to me.Please Help. |
4个回答
嗨,
我可以在14.7中看到为S3AN启用的核心,因此您可以使用它 Reagrds, Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, I can see the core enabled for S3AN in 14.7, so you can use it Reagrds, Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
嗨,
您应该查看用于检查设备支持的数据表.2AN设备已经过PCI测试。 http://www.xilinx.com/support/documentation/ip_documentation/pci32/v4_18/pci_32_ds206.pdf http://www.xilinx.com/products/logicore/pci/system_requirements.htm 指向Spartan-3A,它也包括3AN家族。 您可以查看上面Vanitha显示的快照。 问候, KR -------------------------------------------------- --------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用的帖子。感谢 - ------------------------- ------------------------ ------------------- 以上来自于谷歌翻译 以下为原文 Hi, You should be looking at Datasheet for checking device support.2AN devices are tested for PCI. http://www.xilinx.com/support/documentation/ip_documentation/pci32/v4_18/pci_32_ds206.pdf http://www.xilinx.com/products/logicore/pci/system_requirements.htm points to Spartan-3A which consists 3AN family too. You can look at the snapshot shownby Vanitha above. Regards, KR ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
谢谢大家。我还有一个问题:Xilinx Chipscope是否支持PCI内核?我的意思是我可以使用Chipscope调试我的设计(包括PCI内核)吗?
以上来自于谷歌翻译 以下为原文 Thank you all.I have another question:Does Xilinx Chipscope supprts PCI Core?I mean can I debug my design(including the PCI Core) with Chipscope? |
嗨,
是的你可以 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, Yes you can --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:46 , Processed in 1.636438 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2154
