扫一扫,分享给好友
是否可以将VIVADO用于SPARTAN3?
当我第一次打开VIVADO时,它似乎不是。 是否有适用于SPARTAN3的VIVADO附加软件包? / dindea 以上来自于谷歌翻译 以下为原文 Is it possible to use VIVADO for SPARTAN3? When I first open VIVADO, it seems it is not. Is there an add-on package of VIVADO's for SPARTAN3? /dindea |
2个回答
谢谢您的回答。
我并不感到意外。 一个反问题:ISE 14.7与Windows8兼容吗? 在Windows8下安装它的任何已知问题? 我尝试在Windows8下安装10.1和14.3。 它无法正常工作,安装程序停止工作。 但是,我将它们安装在笔记本电脑上,安装在Windows7下,笔记本电脑后来升级到Windows8。 然后我只是将笔记本电脑上的程序文件夹复制到我的Windows8机器上。 两者都有效。 / dindea 以上来自于谷歌翻译 以下为原文 Thank you for your answer. I am not surprised. A counter-question: Is ISE 14.7 Windows8-compatible? Any known problems to install it under Windows8? I tried to install 10.1 and 14.3 under Windows8. It did not work, the Installer stopped working. However, I had them install on a laptop where they were installed under Windows7, the laptop later upgraded to Windows8. Then I simply copied the program folders fron the laptop to my Windows8 machine. And both work. /dindea |
你好
ISE不支持Window8,但很少有客户成功运行它。 检查以下链接 http://forums.xilinx.com/t5/Installation-and-Licensing/ISE-WebPack-14-7-install-on-Windows-8-1-giving-pn-exe/td-p/510515 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi ISE doesn't support Window8 but few customers had it run on it successfully. Check the below links http://forums.xilinx.com/t5/Installation-and-Licensing/ISE-WebPack-14-7-install-on-Windows-8-1-giving-pn-exe/td-p/510515 Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2166 浏览 7 评论
2608 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2081 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2197 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
430浏览 1评论
1529浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2180浏览 0评论
511浏览 0评论
1645浏览 0评论
GMT+8, 2024-4-28 16:41 , Processed in 1.073783 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
