电子发烧友论坛|
嗨,
我有同样的问题与Spartan-6和xcf04 prom.DONE信号没有高。 所有其他信号(CLK,INIT_B,PROG,DATA)都是okey。 我能做什么? 以上来自于谷歌翻译 以下为原文 Hi, I have same problem with Spartan-6 and xcf04 prom.DONE signal did not go high. All other signal (CLK, INIT_B, PROG, DATA) is okey. What can I do? |
5个回答
这是评估板吗?
如果是这样,你使用的是什么版本的ISE / Impact? ------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 Is this an evaluation board? If so, which one? What version of ISE/Impact are you using? ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
你在BITGEN中设置了DRIVEDONE_HIGH选项吗?
你有什么连接到DONE引脚? 你知道配置是否成功完成(DONE引脚除外?) 什么连接到HSWAPEN和SUSPEND引脚? - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Do you have the DRIVEDONE_HIGH option set in BITGEN? What do you have connected to DONE pin? Do you know if configuration completed successfully (except for DONE pin?) What is connected to HSWAPEN and SUSPEND pins? -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
1)是的
2)连接到舞会上的CE并通过330R连接到+ 3.3V 3)是的 4)0V 以上来自于谷歌翻译 以下为原文 1) Yes 2) connected to CE on prom and via 330R to +3.3V 3) Yes 4) 0V |
当Impact失败时,你应该在输出窗口中获得许多显示状态的行
内部配置逻辑。 通常在该读数中有一些线索。 除此之外, 您应该确保在构建.bit文件时将启动时钟设置为默认值 “CCLK”而不是JTAG或USER。 如果您仍有问题,请发布输出 失败时的影响。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 When Impact fails, you should get a lot of lines in the output window that show the state of the internal configuration logic. Usually there are some clues in that readout. Other than that, you should make sure that when you built your .bit file you set the startup clock to the default of "CCLK" and not JTAG or USER. If you're still having problems, please post the output of the Impact when it fails. -- Gabor -- Gabor |
None
以上来自于谷歌翻译 以下为原文 GUI --- Auto connect to cable... INFO:iMPACT - Digilent Plugin: no JTAG device was found. AutoDetecting cable. Please wait. PROGRESS_START - Starting Operation. Connecting to cable (U*** Port - USB21). Checking cable driver. Driver file xu***_xp2.sys found. Driver version: src=2301, dest=2301. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS 14:35:41, version = 1021. Cable PID = 0008. Max current requested during enumeration is 300 mA. Type = 0x0005. write (count, cmdBuffer, dataBuffer) failed C0000004. Cable Type = 3, Revision = 0. Setting cable speed to 6 MHz. Cable connection established. Firmware version = 2301. File version of C:/Xilinx/13.3/ISE_DS/ISE/data/xu***_xp2.hex = 2401. Firmware hex file version = 2401. Downloading C:/Xilinx/13.3/ISE_DS/ISE/data/xu***_xp2.hex. Downloaded firmware version = 2401. PLD file version = 200Dh. PLD version = 200Dh. PROGRESS_END - End Operation. Elapsed time = 0 sec. Type = 0x0005. ESN option: 0000153AB5E701. Attempting to identify devices in the boundary-scan chain configuration... INFO:iMPACT - Current time: 2012-05-04 15:07:43 PROGRESS_START - Starting Operation. Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6slx4, Version : 2 INFO:iMPACT:1777 - Reading C:/Xilinx/13.3/ISE_DS/ISE/spartan6/data/xc6slx4.bsd... INFO:iMPACT:501 - '1': Added Device xc6slx4 successfully. ---------------------------------------------------------------------- ---------------------------------------------------------------------- '1': : Manufacturer's ID = Xilinx xcf04s, Version : 13 INFO:iMPACT:1777 - Reading C:/Xilinx/13.3/ISE_DS/ISE/xcf/data/xcf04s.bsd... INFO:iMPACT:501 - '1': Added Device xcf04s successfully. ---------------------------------------------------------------------- ---------------------------------------------------------------------- done. PROGRESS_END - End Operation. Elapsed time = 1 sec. '1': Loading file 'C:/Users/sesaesk1/Sanna_Eskelinen/OSU_CHARGE/build/test1.mcs' ... done. '2': Loading file 'C:/Users/sesaesk1/Sanna_Eskelinen/OSU_CHARGE/build/osu_charge_top.bit' ... done. INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory, but the original bitstream file remains unchanged. UserID read from the bitstream file = 0xFFFFFFFF. Data width read from the bitstream file = 1. ---------------------------------------------------------------------- INFO:iMPACT:501 - '2': Added Device xc6slx4 successfully. ---------------------------------------------------------------------- ---------------------------------------------------------------------- INFO:iMPACT - Current time: 2012-05-04 15:07:58 PROGRESS_START - Starting Operation. Maximum TCK operating frequency for this device chain: 15000000. Validating chain... Boundary-scan chain validated successfully. '1': Erasing device... '1': Erasure completed successfully. '1': Programming device... done. '1': Putting device in ISP mode...done. '1': Putting device in ISP mode...done. '1': Verifying device...done. '1': Verification completed successfully. '1': Calculated checksum matches expected checksum, 002d51652 '1': Putting device in ISP mode...done. '1': Putting device in ISP mode...done. '1': Setting user-programmable bits... done. '1': Putting device in ISP mode...done. '1': Programming completed successfully. '1': Programming completed successfully. PROGRESS_END - End Operation. Elapsed time = 17 sec. Cable is not connected. '1': Loading file 'C:/Users/sesaesk1/Sanna_Eskelinen/OSU_CHARGE/build/test1.mcs' ... done. GUI --- Auto connect to cable... AutoDetecting cable. Please wait. PROGRESS_START - Starting Operation. Connecting to cable (U*** Port - USB21). Checking cable driver. Driver file xu***_xp2.sys found. Driver version: src=2301, dest=2301. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS 14:35:41, version = 1021. Cable PID = 0008. Max current requested during enumeration is 300 mA. Type = 0x0005. write (count, cmdBuffer, dataBuffer) failed C0000004. Cable Type = 3, Revision = 0. Setting cable speed to 6 MHz. Cable connection established. Firmware version = 2301. File version of C:/Xilinx/13.3/ISE_DS/ISE/data/xu***_xp2.hex = 2401. Firmware hex file version = 2401. Downloading C:/Xilinx/13.3/ISE_DS/ISE/data/xu***_xp2.hex. Downloaded firmware version = 2401. PLD file version = 200Dh. PLD version = 200Dh. PROGRESS_END - End Operation. Elapsed time = 1 sec. The programming is don't fail when I programming the PROM but the FPGA did not start. If i program the FPGA i get this: Type = 0x0005. ESN option: 0000153AB5E701. INFO:iMPACT - Current time: 2012-05-04 15:43:08 PROGRESS_START - Starting Operation. Maximum TCK operating frequency for this device chain: 15000000. Validating chain... Boundary-scan chain validated successfully. '2': Programming device... LCK_cycle = 1. done. '2': Reading status register contents... [0] CRC ERROR : 0 [1] IDCODE ERROR : 0 [2] DCM LOCK STATUS : 1 [3] GTS_CFG_B STATUS : 0 [4] GWE STATUS : 0 [5] GHIGH STATUS : 0 [6] DECRYPTION ERROR : 0 [7] DECRYPTOR ENABLE : 0 [8] HSWAPEN PIN : 0 [9] MODE PIN M[0] : 1 [10] MODE PIN M[1] : 0 [11] RESERVED : 0 [12] INIT_B PIN : 1 [13] DONE PIN : 0 [14] SUSPEND STATUS : 0 [15] FALLBACK STATUS : 0 INFO:iMPACT:2219 - Status register values: INFO:iMPACT - 0010 0000 0100 1000 INFO:iMPACT:579 - '2': Completed downloading bit file to device. INFO:iMPACT:188 - '2': Programming completed successfully. LCK_cycle = 1. INFO:iMPACT - '2': Checking done pin....done. '2': Programming terminated. DONE did not go high. PROGRESS_END - End Operation. Elapsed time = 1 sec. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 07:10 , Processed in 1.879447 second(s), Total 81, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1816
