你好,
当我调试我的逻辑接口FX3时,我注意到一些我想确认的东西。我们使用的同步从FIFO写模式的FX3 GPIF - II。 根据FX3规格(cyu***3014.pdf page-21),有两种不同的发行方式之一pktend,与去年的数据和一个没有数据(ZLP)。与FX2,fifoaddr必须提出一个周期的早期写数据。 在第一种情况下(pktend W /数据)pktend似乎assocating与写入数据的联系地址,这是在前一个周期的地址。然而,在后者的情况下(pktend W / O数据)的pktend是结合在同一周期的地址。 我的设计管道的地址和数据,在最后一个数据周期的地址可能不保持不变,从以前的周期。 我想知道的是,在第一种情况下,pktend(pktend W /数据)是结合周期是一致的数据写在前一个周期或地址。 如果pktend是结合在同一周期的地址,柏树应该在Fx3文档中提及这样的限制。否则,它会创建一个调试困难神秘的问题。 谢谢你的关注。安艺- 以上来自于百度翻译 以下为原文 Hello, While I was debugging my logic that interfaces to the FX3, I noticed something I would like to confirm. We are using Synchronous Slave FIFO Write Mode of the FX3 GPIF-II. According to the FX3 spec (CYUSB3014.pdf page-21), there are two different ways of issuing PKTEND, one with last data and one without data (ZLP). Unlike FX2, FIFOADDR must be presented a cycle earlier to write data. In the first case (PKTEND w/ data) PKTEND seems assocating with the address the write data is associating with, which is the address in the previous cycle. However, in the latter case (PKTEND w/o data) the PKTEND is associating with the address in the same cycle. As my design pipelines the address and the data, the address in the last data cycle *may* not stay the same from the previous cycle. I would like to know whether the PKTEND in the first case (PKTEND w/ data) is associating with the address in the previous cycle or the address in the cycle that is coincident to the write data. If the PKTEND is associating with the address in the same cycle, Cypress should mention such restriction in the FX3 documentation. Otherwise, it would create a hard-to-debug mysterious problem. Thank you for your attention. Aki- |
1个回答
你好,
在第22页中有一个解释,解释了FIFOADDR引脚的状态,同时使用PKKAND PIN。请澄清它的哪一部分尚不清楚。 当做, 阿南德 以上来自于百度翻译 以下为原文 Hi, In page 22 there is a explanation which explains that state of FIFOADDR pins as well while using PKTEND pin. Please clarify which part of it is not clear. Regards, Anand |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2103 浏览 1 评论
1849 浏览 1 评论
3667 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1784 浏览 6 评论
1534 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
420浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
435浏览 2评论
381浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
913浏览 2评论
GMT+8, 2024-12-22 17:45 , Processed in 1.054254 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
