电子发烧友论坛|
我有两个CysB3KIT-03探索套件。在这里,我遵循“AN8216-设计GPIF II主接口”指南,以便在主机和从属FIFO之间交换两个主机之间的数据。
我下载并上传了从设备和主设备(AutoSaveL.IMG和AutoStudio .img)的预构建固件映像。上传后,CyPress USB控制中心软件没有显示什么(在上传CyPress USB控制中心将两个设备列为CyPress FX3 USB引导加载设备)之前。然后,我在设备管理器中交叉检查,两个设备驱动程序都没有安装(两者在其他设备中显示为FX3)。我已经尝试了所有的样品从SDK套件,如LED闪烁,流光等,所有工作的罚款,但不是这个样本。我已经尝试了为设备安装驱动程序的所有选项,但都失败了。 原因何在?请建议。 我的机器操作系统是:Windows 10,Windows 7 以上来自于百度翻译 以下为原文 I have two CYUSB3KIT-003 explore kits. Here, I am following "AN87216 - Designing a GPIF II Master Interface" guide to make exchange of data between two hosts as Master and Slave FIFO. I downloaded and uploaded pre-built firmware images for both the slave device and master device (Autoslave.img and Automaster.img). After uploading, Cypress USB Control Center software shows nothing (before uploading Cypress USB Control Center lists both devices as Cypress FX3 USB Bootloader device). Then, I cross-checked in the device manager, both the device drivers not installed (both are shown as FX3 in other devices). I have tried all the samples from the SDK kit like LED blink, streamer, etc. All the working fine but not for this sample. I have tried all options to install drivers for the device but failed. What could be the reason? Kindly suggest. My machine OS is: Windows 10, Windows 7 |
2个回答
你好,
请尝试手动绑定驱动程序: 在设备管理器中,双击FX3--GT驱动程序Tab-GT;更新驱动程序&浏览我的计算机以驱动软件-GT;让我从驱动程序列表中拾取-GT;具有磁盘-Gt;(在C:程序文件(x86) CyPress EZ-USB FX3 SDK 1.3 驱动程序)中选择CysB3.NIF文件-GT;选择蚂蚁列表,如CyPress StuffER应用程序--gt;单击Next和OK。 现在你应该能看到控制中心的设备了。 当做, - Madhu Sudhan 以上来自于百度翻译 以下为原文 Hi, Please try manually binding the drivers: In the device manager, Double click FX3 -> Drivers Tab -> Update Driver -> Browse my computer for Driver Software -> Let me pick up from the list of drivers -> Have Disk -> (Select the cyu***3.inf file in the location c:Program Files (x86)CypressEZ-USB FX3 SDK1.3driver) -> Select ant listing such as Cypress Streamer Application" -> Click Next and OK. Now you should be able to see the device in the control center. Regards, - Madhu Sudhan |
dfzvzs 发表于 2018-10-23 18:00 谢谢Madhu!这真的有效! 我选择了“FX3--GT;驱动程序Tab& & Gt;更新驱动程序& GT;浏览我的计算机驱动软件-GT;让我从驱动程序列表中获取& GT;USB控制器驱动程序& GT;从WIN7YXX64文件夹(Workfor Windows 10)获得磁盘& GT;CysB3.INF)。关于& &下一步&好; 现在,我可以在两台机器上运行Surror应用程序来测试主和从FIFO样本。我注意到主从FIFO工作得很好,没有任何数据损坏,但在从奴隶FIFO向主设备发送数据时,我得到了垃圾数据(损坏)。 例如(测试CyPress USB控制中心):发送“从主数据”,我能够从从属设备获得相同的数据。但是,当把相同的数据发送回主机时,我得到一些损坏的十六进制数据。你能告诉我实际问题在哪里吗? 可能的问题与张贴在这里GPIF II硕士和从奴隶转换问题(M到S通过,但S到M失败!) 以上来自于百度翻译 以下为原文 Thanks Madhu! That actually works! I selected "FX3 -> Drivers Tab -> Update Driver -> Browse my computer for Driver Software -> Let me pick up from the list of drivers -> USB Controller driver -> Have Disk -> cyu***3.inf from the Win7_x64_folder (works for Windows 10) -> Selected FX3 Cypress Streamer Application -> Next -> OK" Now, I am able to run streamer application on two machines to test Master and Slave FIFO sample. I noticed Master to Slave FIFO is working great without any data corruption but while sending data from Slave FIFO to Master device, I am getting garbage data (corrupted). for example (testing on Cypress USB Control Center): sending "DATA FROM MASTER", I am able to get the same data on Slave device. But while sending the same data back to the Master, I get some corrupted hex data. Can you please suggest me where the actual problem is? Possible the same question as posted here GPIF II Master & Slave Transform Problem (M to S Pass But S to M Fail!) |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 05:37 , Processed in 0.764084 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1243
