电子发烧友论坛|
你好,
FX3软件“GPIF II设计器”在哪里可以下载? 可用的GPIF设计器的日期为2003,似乎没有支持FX3内部? 当做, d. 以上来自于百度翻译 以下为原文 Hi, where can the software "GPIF II Designer" be downloaded for FX3 ? The available GPIF designer is dated from 2003 and seems to have no support for FX3 inside ? Regards, D. |
6个回答
GPIF II设计器应在SDK的当前版本中可用。请与您的营销联系,以获得最新版本。请注意,当前GPIF II设计器只允许用户尝试几个预先构建的接口,不允许您设计自己的自定义接口。这将在下一个版本中得到支持。
当做, 阿南德 以上来自于百度翻译 以下为原文 GPIF II designer should be available in the current release of the SDK. Please check with your marketing contact to get the latest release. Please be aware however that the current GPIF II designer only allows the user to try a few pre-built interfaces and would not allow you to design your own custom interface. That would be supported in the next release. Regards, Anand |
你好,
现在我已经获得SDK的384版本(从ELF2IMG程序中获益),但是我找不到GPIF 2Dead应用程序。 这是当前SDK的正确版本吗? 当做, d. 以上来自于百度翻译 以下为原文 Hi, I've got the release 384 of the SDK now (to benefit from elf2img program), but I cannot find the GPIF 2 designer application. Is this the correct version of the current SDK ? Regards, D. |
对不起的。我的错。
看来发布还没有发生。一旦完成,我会更新你的。 当做, 阿南德 以上来自于百度翻译 以下为原文 Sorry. My bad. It seems that release hasn't happened yet. I'll update you once it is done. Regards, Anand |
使用少量预构建的版本现在可以单独安装了。
当做, 阿南德 以上来自于百度翻译 以下为原文 The release with the few prebuilt configurations is available now as a separate installable. Regards, Anand |
你好,
有一个客户要求FX3的GPII设计器。我记得从培训中,只有几个接口的例子是可用的,客户应该坚持这些,因为GPII设计师没有准备好黄金时段。请让我知道这些例子是什么(GPII接口),一个可以使用一个VS其他。当客户可以设计自己的接口GPII时,也可以进行任何更新。 箭头专家 拉里 以上来自于百度翻译 以下为原文 Hello, Have a customer asking for GPII designer for FX3. I remember from training only a few interface examples are available and that the customer should stick with these as the GPII designer wasn't ready for prime time. Please let me know what these examples are(GPII interfaces), whay one whould use one Vs the others.. Also any update when the customer can design his own interface GPII. Cypress Specialist at Arrow Larry |
嗨,拉里,
在这个时间点的支持模式是 异步存储器 同步ADMUX 异步从属FIFO 同步从属FIFO 异步静态随机存储器 当做, 阿南德 以上来自于百度翻译 以下为原文 Hi Larry, The supported modes at this point of time are Async ADMUX Sync ADMUX Async slave FIFO sync slave FIFO Async SRAM Regards, Anand |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 19:25 , Processed in 1.168840 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1891
