电子发烧友论坛|
您好我试图通过NI-gpib-u*** A转换器将E4406A连接到我的电脑。它与john miles ssm工作得非常好,但是当我尝试连接到我的E4444A原始软件时它失败了。
已经在整个安捷伦和NI上搜索了答案,并找到了安捷伦应用笔记5990-3731EN,并按照说明完成了操作。 安装了NImax和Agilent IOlibs 16并排模式并启用了郁金香激活的护照连接,但无法连接到Agilent gpib和NI gpib。 任何人都有想法什么会出错? 哈迪 以上来自于谷歌翻译 以下为原文 Hello I am trying to connect an E4406A to my pc via an NI-gpib-u*** A converter.It works excellent with john miles ssm,but when I try to connect to my E4444A original software it fails. Have searched all over Agilent and NI for an answer and found Agilent app note 5990-3731EN,and have done as explained. Installed NImax and Agilent IOlibs 16 in side by side mode and enabled passport connection with tulip activated but cant connect to Agilent gpib and NI gpib. Anyone have an idea whats going wrong?? Hardy |
6个回答
嗨哈迪 - E4440A从未支持过E4406A。
用于信号分析仪的Intuilink工具栏非正式地能够从E4406A获取屏幕截图。 我不确定这种非官方的支持是否被打破。 我们有一些示例程序可以从www.agilent.com/find/sa_programming中获取仪器的屏幕图像。 您必须调整PSA程序以便能够使用E4406A,因为E4406A具有通过SCPI抓取屏幕图像的不同命令。 关于将Agilent GPIB硬件与NI 488.2兼容程序一起使用,Agilent IO套件下有一个设置,可以为488程序启用GPIB卡。 单击工具 - > Agilent 488,然后选中该复选框以启用适用于488程序的Agilent GPIB卡。 从E4406A获取屏幕图像的另一种方法是通过FTP。 您可以将图像保存到仪器的闪存中,然后使用用户名FTP将其保存到仪器中:vsa和密码:service。 问候 - 以上来自于谷歌翻译 以下为原文 Hi Hardy - The E4406A was never supported by E4444A. The Intuilink Toolbar for Signal Analyzer unofficially was able to grab screen captures from the E4406A. I’m not sure if that unofficial support was broken. We have some example programs for grabbing screen images from instruments at www.agilent.com/find/sa_programming. You would have to tweak the program for PSA to be able to work with E4406A, since the E4406A had a different command for grabbing screen images via SCPI. Regarding using Agilent GPIB hardware with NI 488.2 compatible programs, there is a setting under the Agilent IO Suite to Enable GPIB card for 488 program. Click on Tool -> Agilent 488 and then check the checkbox to enable Agilent GPIB cards for 488 programs. Another way to get screen images out of the E4406A is via FTP. You can save an image to the instrument’s flash memory and then FTP into the instrument with the user name: vsa and password: service. Regards - |
醉狼工作室 发表于 2019-3-11 14:20 Tabbott感谢您的帮助。感谢E4444A与E4406A合作的文章 - 但您是对的! 已经尝试过使用intuilink的方式,并且不知何故它似乎工作 - 至少可以看到itilinkink可以看到E4406A,但是我的办公室软件包出现了一些问题,所以我会得到另一个问题。 使用ftp的方式似乎是最好的镜头,因为安捷伦连接专家很容易看到E4406A局域网(192.168.0.106)。但是当使用您的用户和密码调用ftp-root(192.168.0.106)时,我可以看到文件 - -filesets,licenses,.xinitrc,config,makepipe ..... statefiles .... etc -------但没有屏幕文件?? 我必须做错事。当我在E4406A中将屏幕图像保存到c(闪存)时,它放入/ users / ftp / screen - 不知道如何到达那里! 哈迪 以上来自于谷歌翻译 以下为原文 Tabbott Thanks for Your kind help.Strange the litterature says E4444A works with E4406A-but You are right!. Have tried the way with intuilink,and somehow it seemed to work-at least the intuilink can see E4406A,but my office package made some problems so I will get another. The way with ftp seems to be the best shot,as agilent connection expert easy see the E4406A lan(192.168.0.106).But when calling ftp-root at (192.168.0.106) with Your user and password I can see the files ---filesets,licenses,.xinitrc,config,makepipe.....statefiles....etc-------but no screen files??. I must do something wrong.When I save a screen image to c(flash) in the E4406A its put into /users/ftp/screen--dont know how to get there!. Hardy |
60user143 发表于 2019-3-11 14:28 嗨塔博特。 问题解决了,我升级固件后你的ftp工作方式。 谢谢哈代 以上来自于谷歌翻译 以下为原文 Hi Tabbott. Problem solved,Your way with ftp works after I have upgraded my firmware. Thanks Hardy |
感谢分享好消息哈迪! 听到那个消息很开心 - 以上来自于谷歌翻译 以下为原文 Thanks for sharing good news Hardy! Glad to hear it - |
哈迪你现在用的是哪个版本? 最新的E4406? 卡斯滕 以上来自于谷歌翻译 以下为原文 Hardy What version are you using now ? The latest for the E4406 ? Carsten |
嗨Carsten我正在使用来自agilents vsa网站的最新固件。 欢迎您联系在线 - 我们都在哥本哈根地区。 电话。 29281995。 以上来自于谷歌翻译 以下为原文 Hi Carsten I am using the latest firmware from agilents vsa site. You are welcome to contact ofline--we are both in copenhagen area. phone. 29281995. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:56 , Processed in 0.774307 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1691
