电子发烧友论坛|
我最近重新投入使用34970A,这是我在一年左右没用过的。
我正在使用新计算机,并已下载最新版本的Benchlink软件。 我有几个问题。 我在另一篇文章中已经问过一个问题,那就是每次打开设备时我都会收到741错误代码。 另一个是该单元未通过自检程序。 第三,Benchlink计划不承认34970A已连接。 我尝试了“查找”功能但没找到它。 它设置为RS-232连接,波特率为9600.当我在一年前断开此设备时,它正在与之前版本的Benchlink上运行的另一台计算机进行正常通信。 当我点击帮助时,它告诉我去设备附带的CD上的连接专家,但我的CD将不再运行,因为它太旧了。 有任何想法吗? 谢谢。 以上来自于谷歌翻译 以下为原文 I recently put back in service a 34970A that I hadn't used in a year or so. I'm using a new computer and have downloaded the newest version of Benchlink software. I'm having a couple issues. One I already asked about in another post, which is that I keep getting a 741 error code every time I turn the unit on. Another is that the unit fails the self test procedure. Third is that the Benchlink program does not recognize that the 34970A is connected. I tried the "find" function and it didn't find it. It's set for RS-232 connection with a baud rate of 9600. When I disconnected this unit a year ago it was working and communicating fine with the other computer running on a previous version of Benchlink. When I click on help it tells me to go to the connection expert that is on the CD that came with the unit, but my CD will no longer run because it's so old. Any ideas? Thanks. |
1个回答
BLDL使用Agilent IO Libraries或NI IO Libraries进行通信。
如果您遇到连接问题,通常使用ACE(Agilent Connection Expert)或NI MAX来查找34970A将解决问题。 下载并安装IO Libraries。 请访问www.agilent.com/find/iosuite。 这是一个免费下载。 以上来自于谷歌翻译 以下为原文 BLDL uses the Agilent IO Libraries or NI IO Libraries for communications. If you are having connection problems, usually using ACE (Agilent Connection Expert) or NI MAX to find the 34970A will fix the problem. Download and install IO Libraries. Go to www.agilent.com/find/iosuite. It's a free download. |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
415浏览 0评论
/9
GMT+8, 2025-12-1 16:22 , Processed in 1.690364 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4593
