电子发烧友论坛|
我有34972A,我们通过局域网与它通信。
昨天我懒得在关闭设备之前停止我的Benchlink 3会话,现在当我尝试通过BL连接时,我不断收到“由于超时操作失败”的消息。 IO库看起来很好,说一切都好,但是如果我尝试做IDN就失败了。 我重置了34972并重新启动了计算机。 没有人工作,我没有想法。我不知道该做什么,但无法想象我在连接到BL时关闭了全新的34972A.Thanks,Ryan 以上来自于谷歌翻译 以下为原文 I have a 34972A and we are communicating to it through LAN. Yesterday I was too lazy to go stop my session of Benchlink 3 before turning the unit off and now I keep getting a "Operation failed due to timeout" message when I try to connect through BL. IO Libraries sees it fine, says everything is OK, but if I try to do an IDN it fails. I have reset the 34972 and restarted the computer. Neither one worked and I am out of ideas. I don't know what to do but cannot imagine I bricked a brand new 34972A by turning it off while connected to BL. Thanks, Ryan |
2个回答
你的正确,你没有砖34972A砖。
使用带有GPIB的数据记录器(我认为使用USB),您可以暂停程序,关闭仪器电源然后再打开,然后继续使用“旧”连接仍在工作的程序。您无法使用LAN执行此操作 - 一次 仪器关闭,连接已完成且无法恢复。应用程序必须在仪器重新打开后获得新的LAN连接 - 旧的LAN连接不存在。 以上来自于谷歌翻译 以下为原文 Your correct, you did not brick your 34972A. Using datalogger with GPIB (and I think with USB), you can pause a program, cycle the instrument power OFF and then back ON, and then continue the program with the “old” connection still working. You cannot do this with LAN – once the instrument goes down, the connection is GONE and does not come back. The application must acquire a new LAN connection after the instrument is powered back on – that old LAN connection is not there. |
我试图在BL中建立一个新的LAN连接。
我删除了旧连接并尝试重新建立。 我做了一个发现,那是我收到超时消息的时候。 我还缺少另一步吗?谢谢,瑞恩 以上来自于谷歌翻译 以下为原文 I have tried to set up a new LAN connection in BL. I deleted the old connection and tried to reestablish. I do a find and that is when I get the timeout message. Is there another step I am missing? Thanks, Ryan |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:28 , Processed in 0.607569 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3582
