电子发烧友论坛|
您好,我有一张34970A,里面有34901A卡。
我试图通过在Windows 7 Professional和Bench Link Data Logger 3上运行的笔记本电脑来使用它。我有一台运行的是Keysight Connection Expert,还有一台labview 2013.起初,我可以通过BenchLink使用34970A,但我不能 在NI MAX中找到34970A。 我了解到我必须在“设置”中“选项”下的“Keysight 488选项”菜单中激活一个选项。 (这需要我没有的管理权限,所以这非常繁琐)一旦我这样做了,现在我可以在Keysight Communication Expert和NI MAX中看到34970A。 但是现在我无法通过BenchLink使用34970A。 当我尝试通过在BenchLink上的“扫描和日志数据”选项卡中按“开始/停止”来收集数据时,会出现一个弹出窗口,显示“GPIB0 :: 10 :: INSTR:无法在本地模式下执行命令” “。 和34970A发出哔哔声。 当我通过前面板本地配置34970A然后尝试通过BenchLink收集数据时,它会清除34970A上的设置,所有通道都变为“OPEN”。 我想我需要在“设置”中“选项”下的“Keysight 488选项”菜单中停用该选项,但我想知道是否有任何我应该采取的措施来解决此问题。 先谢谢你! 以上来自于谷歌翻译 以下为原文 Hello, I have a 34970A with a 34901A card in it. I am trying to use it through a laptop running on Windows 7 Professional and Bench Link Data Logger 3. I have a Keysight Connection Expert running and also a LabVIEW 2013. At first, I was able to use 34970A through BenchLink, but I could not find 34970A in NI MAX. I had learned that I had to activate an option in the "Keysight 488 options" menu under "Options" in "Settings". (This requires administrative privilege that I don't have, so this is very tedious to do) Once I did it, now I can see 34970A in Keysight Communication Expert as well as in NI MAX. But Now I cannot use 34970A through BenchLink. When I try to collect data by pressing "Start/Stop" in "Scan and Log Data" tab on the BenchLink, there is a pop-up window saying "GPIB0::10::INSTR: Not able to execute command in local mode." and 34970A beeps. When I locally configure the 34970A through its front panel and then try to collect data through the BenchLink, it wipes out the setting on the 34970A and all channels become "OPEN". I think I need to deactivate the option in the "Keysight 488 options" menu under "Options" in "Settings", but am wondering if there are anything I should do to resolve this issue. Thank you in advance! |
1个回答
在启用Keysight 488的菜单中,有一个框,在系统控制器时显示Assert REN。
确保选中此框。 现在听起来它没有被检查,所以仪器没有被放入遥控器。 因此,您不断看到的错误消息是在本地模式下。 以上来自于谷歌翻译 以下为原文 In the menu where you enabled Keysight 488, there is box that says Assert REN when System Controller. Make sure this box is checked. Right now it sounds like it is not checked, so the instrument is not being put into remote. Thus the error messages you keep seeing about it being in local mode. |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 18:49 , Processed in 0.698542 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2955
